DHCP issue - clients connect sometimes
  • 1.  DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 07:09 AM
    The DHCP server is leasing IP addresses. Some devices will get an IP the first and after the client is shutdown or rebooted, they cannont get an IP again. Other clients connect fine but if they go to a screensaver or sleep  mode, they have to connect to another network then back to the network they need to be on. Lastly some just don't get an IP at all. I turned on debugging on the controller and I see the IP the client would get but the client never gets it.
  • 2.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 07:31 AM
    It sounds as though the client cannot obtain/renew an IP if it is in the client table and already assigned a role; but if they connect to another network and back again, they are able to (coming in anew).
    Please share the output of the following for the role the clients are in when they cannot renew/obtain an IP.
    show rights <nameofrole>
  • 3.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 07:54 AM
    (ARUBA_CTR_LOCAL) #show rights xxxx-hosp-pol
    Derived Role = 'xxxx-hosp-pol'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Assigned VLAN = 104
     Periodic reauthentication: Disabled
     ACL Number = 69/0
     Max Sessions = 65535
    access-list List
    Position  Name      Location
    1         allowall
    2         qakbot
    allowall
    Priority  Source  Destination  Service  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
    1         any     any          any      permit                           Low                                                           4
    qakbot
    1         any     any          udp 16666  deny                             Low                                                           4
    2         any     any          udp 16669  deny                             Low                                                           4
    3         any     any          tcp 16666  deny                             Low                                                           4
    4         any     any          tcp 16669  deny                             Low                                                           4
    Expired Policies (due to time constraints) = 0
  • 4.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 08:36 AM
    I know you said you turned on debugging, but did you turn on DHCP debugging?  Try the following:
    logging level debugging network subcat dhcp
    attempt to reconnect and obtain IP
    show log network | all include <MAC>
    Run the same test getting a successful IP; so switching networks for example.
    when you are done, disable it:
    no logging level debugging network subcat dhcp
  • 5.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 09:13 AM
    I ran it but showed nothing. I added logging level debugging network process dhcpd.
    Succesful IP:
    (ARUBA_CTR_LOCAL) (config) #show log network all | include 00:21:5d:8b:98:68
    Feb 7 09:01:52 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x40 opcode 0x5a ingress 0x1612 vlan 104 egress 0x0 src mac 00:21:5d:8b:98:68
    Feb 7 09:01:52 :202538:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: RELEASE 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:02:18 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x119a vlan 104 egress 0x68 src mac 00:21:5d:8b:98:68
    Feb 7 09:02:18 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: DISCOVER 00:21:5d:8b:98:68 Options 74:01 3d:0100215d8b9868 0c:4169724d61676e6574 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc00
    Feb 7 09:02:18 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=00:21:5d:8b:98:68
    Feb 7 09:02:18 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: DISCOVER 00:21:5d:8b:98:68 Options 74:01 3d:0100215d8b9868 0c:4169724d61676e6574 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc00
    Feb 7 09:02:18 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: OFFER 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:02:18 :202527:  <DBUG> |dhcpdwrap| |dhcp| RelayToClient: OFFER dest=172.20.104.5 client yiaddr=172.20.104.5 MAC=00:21:5d:8b:98:68
    Feb 7 09:02:18 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: OFFER 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:02:18 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 00:21:5d:8b:98:68 reqIP=172.20.104.5 Options 3d:0100215d8b9868 36:ac1092a6 0c:4169724d61676e6574 51:0000004169724d61676e65742e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc0100
    Feb 7 09:02:18 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 00:21:5d:8b:98:68 reqIP=172.20.104.5 Options 3d:0100215d8b9868 36:ac1092a6 0c:4169724d61676e6574 51:0000004169724d61676e65742e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc0100
    Feb 7 09:02:18 :202544:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:02:18 :202086:  <INFO> |dhcpdwrap|  netlink_arp_changed(): ker_mac 00:21:5d:8b:98:68 pkt_mac 00:21:5d:8b:98:68 cip 172.20.104.5
    Feb 7 09:02:18 :202544:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: ACK 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:03:39 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x40 opcode 0x5a ingress 0x119a vlan 104 egress 0x0 src mac 00:21:5d:8b:98:68
    Feb 7 09:03:39 :202538:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: RELEASE 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:04:13 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x1612 vlan 104 egress 0x68 src mac 00:21:5d:8b:98:68
    Feb 7 09:04:13 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: DISCOVER 00:21:5d:8b:98:68 Options 74:01 3d:0100215d8b9868 0c:4169724d61676e6574 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc00
    Feb 7 09:04:13 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=00:21:5d:8b:98:68
    Feb 7 09:04:13 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: DISCOVER 00:21:5d:8b:98:68 Options 74:01 3d:0100215d8b9868 0c:4169724d61676e6574 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc00
    Feb 7 09:04:13 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: OFFER 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:04:13 :202527:  <DBUG> |dhcpdwrap| |dhcp| RelayToClient: OFFER dest=172.20.104.5 client yiaddr=172.20.104.5 MAC=00:21:5d:8b:98:68
    Feb 7 09:04:13 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: OFFER 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:04:13 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 00:21:5d:8b:98:68 reqIP=172.20.104.5 Options 3d:0100215d8b9868 36:ac1092a6 0c:4169724d61676e6574 51:0000004169724d61676e65742e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc0100
    Feb 7 09:04:13 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 00:21:5d:8b:98:68 reqIP=172.20.104.5 Options 3d:0100215d8b9868 36:ac1092a6 0c:4169724d61676e6574 51:0000004169724d61676e65742e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f21f92b 2b:dc0100
    Feb 7 09:04:13 :202544:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: ACK 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Feb 7 09:04:13 :202086:  <INFO> |dhcpdwrap|  netlink_arp_changed(): ker_mac 00:21:5d:8b:98:68 pkt_mac 00:21:5d:8b:98:68 cip 172.20.104.5
    Feb 7 09:04:13 :202544:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: ACK 00:21:5d:8b:98:68 clientIP=172.20.104.5
    Unsuccessful IP (gets Windows default IP when it cannot get IP (169.254.x.x)
    (ARUBA_CTR_LOCAL) (config) #show log network all | include 84:3a:4b:88:33:60
    Feb 7 09:06:04 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x119a vlan 104 egress 0x68 src mac 84:3a:4b:88:33:60
    Feb 7 09:06:04 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: DISCOVER 84:3a:4b:88:33:60 Options 3d:01843a4b883360 0c:49532d572d3130 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:04 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=84:3a:4b:88:33:60
    Feb 7 09:06:04 :202534:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: DISCOVER 84:3a:4b:88:33:60 Options 3d:01843a4b883360 0c:49532d572d3130 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:04 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: OFFER 84:3a:4b:88:33:60 clientIP=172.20.104.4
    Feb 7 09:06:04 :202527:  <DBUG> |dhcpdwrap| |dhcp| RelayToClient: OFFER dest=172.20.104.4 client yiaddr=172.20.104.4 MAC=84:3a:4b:88:33:60
    Feb 7 09:06:04 :202546:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: OFFER 84:3a:4b:88:33:60 clientIP=172.20.104.4
    Feb 7 09:06:04 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:04 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:07 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x119a vlan 104 egress 0x68 src mac 84:3a:4b:88:33:60
    Feb 7 09:06:07 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:07 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=84:3a:4b:88:33:60
    Feb 7 09:06:07 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:15 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x119a vlan 104 egress 0x68 src mac 84:3a:4b:88:33:60
    Feb 7 09:06:15 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:15 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=84:3a:4b:88:33:60
    Feb 7 09:06:15 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 84:3a:4b:88:33:60 reqIP=172.20.104.4 Options 3d:01843a4b883360 36:ac1092a6 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:57 :202541:  <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x41 opcode 0x5a ingress 0x1612 vlan 104 egress 0x68 src mac 84:3a:4b:88:33:60
    Feb 7 09:06:57 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan104: REQUEST 84:3a:4b:88:33:60 reqIP=192.168.1.63 Options 3d:01843a4b883360 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
    Feb 7 09:06:57 :202533:  <DBUG> |dhcpdwrap| |dhcp| Relayed: DISCOVER server=172.16.146.166 giaddr=172.20.104.1 MAC=84:3a:4b:88:33:60
    Feb 7 09:06:57 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan1: REQUEST 84:3a:4b:88:33:60 reqIP=192.168.1.63 Options 3d:01843a4b883360 0c:49532d572d3130 51:00000049532d572d31302e6d696c7265672e6f7267 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
  • 6.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 09:23 AM
    What VLAN should the client be on; 1 or 104?  I see requests for both.
  • 7.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 09:49 AM
    The gateway resides on the controller is on VLAN 1 and is the gateway. The clients go to a DHCP server which assigns a VLAN 104.
  • 8.  RE: DHCP issue - clients connect sometimes
    Posted Feb 07, 2014 04:23 PM
    OK; maybe I am confusing your setup.    I am wondering why it appears the client is asking for an IP on VLAN 1 at times.   I see that you have VLAN 104 tied to the role; what is the default VLAN for the Virtual AP?  Also, what type of authentication is used on the network?
  • 9.  RE: DHCP issue - clients connect sometimes
    Posted Feb 12, 2014 01:29 PM
    Does it matter that I have an IP address helper on ther controller?  Or should it be on the core switch?
    The controller is VLAN 1, which is the gateway for all wireless clients. Each SSID in the Virtual AP has a VLAN (20, 104 and 108). The APs uses VLAN 47. The DHCP server is on VLAN 146. The IP address helper address is the IP of the DHCP server.
    I am puzzled becauseI have a test client is connected fine all day but when I come in the next morning, it has limited access. I connect to another network and back and it is fine.
