  • 1.  DHCP issues
    Posted Apr 15, 2015 07:06 AM
    I have no past experience with Aruba IAP-105 devices. Issue is following, i have 3 AP's installed.
    They are connected to network, let's call it Corporate1. I have created wlan for Corporate1 and DHCP is a server on that network. There is no issues with this setup. Also i need separate wlan for corporate2 and guest wlan. I would like to use DHCP server on Aruba devices, lets say 10.15.1.1 for corporate2 and 192.168.1.1 for guest wlan. I have created two DHCP scopes and both have own vlan id's, corporate2 is vlan 15 and guest is 192. When connecting to these two wlans, clients are not receiving ip-addresses.
    How I should assign these DHCP scopes per wlan?
  • 2.  RE: DHCP issues
    Posted Apr 15, 2015 07:40 AM
    Please follow thsese steps,
    Step 1 : Create Local DHCP scopes and map to desired VLANs as shown in the snap shot.
    Step 2 : Create WLAN ( SSID) and select "Client IP assignment as " VC assignment and " Client VLAN assignment " as "Custom " and select the DHCP scope VLAN accordingly from the dropdown list.
    Please feel free for any further help on this.
  • 3.  RE: DHCP issues
    Posted Apr 17, 2015 05:10 AM
    there is no such setting:
  • 4.  RE: DHCP issues
    Posted Apr 17, 2015 05:38 AM
    Which code version you are using ?? in old version this option is not available.
    Please feel free for any further help required.
  • 5.  RE: DHCP issues
    Posted Apr 20, 2015 01:37 AM
    Version:
    6.3.1.8-4.0.0.9_47220
  • 6.  RE: DHCP issues
    Posted Apr 20, 2015 10:07 AM
    This code (4.0.x) do not support that. please upgrade the code to the latest (4.3.x) will find  all the required DHCP options.
  • 7.  RE: DHCP issues
    Posted Mar 01, 2017 07:26 AM
    Apologies for digging up an old thread, but I have the VLAN & DHCP set as you suggested but clients only get IPs from the Magic VLAN, is there a way to turn this off ?
    IAP-215 running 6.4.4.8-4.2.4.5_57965
  • 8.  RE: DHCP issues
    Posted Mar 01, 2017 07:35 AM
    Your VLAN should be network assigned to get DHCP from the ethernet port of the AP (VLAN 1 by default), instead of the internal DHCP server of the instant (Virtual Controller Assigned.)
  • 9.  RE: DHCP issues
    Posted Mar 01, 2017 08:30 AM
    Thanks for your reply and sorry if my post wasnt very clear.
    We have 3 networks, EG:
    Corp Net, Network assigned DHCP/ VLAN 1, 802.1x Auth
    Guest Net, VC assigned 172.16.x.x/ VLAN 2, Captive Portal
    & Special Net, which is VC assigned 192.x.x.x/ VLAN 3, Mac Auth
    Corp Net works fine and gets 10.x.x.x IP all works fine.
    Guest Net gets IP 172.33.99.x (Magic VLAN IP) and has no network/internet access, & no Captive Portal access
    Special Net initially gets 172.33.99.x IP and we get DHCP lookup fail errors on the client, then client drops.
    How do I force it to VLAN 2/3 for correct DHCP range?
    Regards
    Paul.
  • 10.  RE: DHCP issues
    Posted Mar 01, 2017 09:28 AM
    Thanks for your reply and sorry if my original post was not clear.
    We have 3 Networks.
    Corp is DHCP from network/ 10.x.x.x/ VLAN 10/ 802.1x Auth
    All works fine!
    Guest is VC DHCP/ 172.16.x.x / VLAN 200/ Captive Portal
    Only gets 172.33.x.x IP (Magic VLAN) and no CP page
    Special is VC DHCP/ 192.168.x.x/ VLAN 500/ MAC Auth
    Only Gets 172.33.x.x IP and DHCP lookup fail on client then client drops.
          EDIT:
            On further inspection the IP is a hang over from connecting to the Guest as it fails over to it.
    How do I force VLAN/ DHCP for each SSID ?
