I have the Ap's setup as RAPand they are communicating with the controller in tunnel mode
My Issue is that I can connect to the AP as a guest or secure user , however I don't get an IP Address from the AP for the client device .
The wired guest and the wireless guest share the same vlan 147
The wired guest clients do get a dhcp ip address from the Non Aruba dhcp server.
The existing Cisco Aps can hand out Dhcp ip address to client on the same vlan 37 as secure user
The Controller and clearpass server are at the Data center
The APs are at the corporate office
The Ap's are connected to Cisco 6509 switches and the two local vlans 37,147 that only exist on that switch .
All connections to other floors and the data center travel over layer3 links no vlan trunking between switches local or to the Data Center.
