DHCP - Just noticed a weird thing ?
  • 1.  DHCP - Just noticed a weird thing ?
    Posted Dec 11, 2013 07:45 PM
    6 of the 7 IAP-105's Have a different DHCP Setup according to the System Support Logs
    I have been having some weird DHCP Issues So I was Looking around at the System Support Logs
    I ran the command : Ap Internal DHCP Status
    It Shows that the MAIN or CONTROLER IAP-105 In this case 1-West has the Correct Settings
    192.168.10.0 / 255.255.255.0
    	vlan-id=3333
    	dhcp-range=192.168.10.3,192.168.10.254,255.255.255.0,60m
    	dhcp-option=1,255.255.255.0
    	dhcp-option=3,192.168.10.1
    	dhcp-option=6,208.67.222.222,208.67.220.220
    	dhcp-option=54,192.168.10.1
    However the Other 6 - IAP-105 Show ...
    	vlan-id=3333
    	dhcp-range=172.31.98.3,172.31.99.254,255.255.254.0,12h
    	dhcp-option=1,255.255.254.0
    	dhcp-option=3,172.31.98.1
    	dhcp-option=6,10.1.10.1
    	dhcp-option=54,172.31.98.1
    Wondering .. Should not all the iap-105's Show the Same thing ?
  • 2.  RE: DHCP - Just noticed a weird thing ?
    Posted Dec 11, 2013 09:34 PM
    The simple answer is that only one IAP can provide DHCP at one time.  Maybe your network is setup differently.
  • 3.  RE: DHCP - Just noticed a weird thing ?
    Posted Dec 11, 2013 09:36 PM
    The 172.31.x.x is the internal default DHCP used by the IAP when you select the option of Virtual Controller Assigned network or when you connect to the "instant SSID"
    The other one looks like you configured that one?
    Are those IAPs part of the same cluster ?
  • 4.  RE: DHCP - Just noticed a weird thing ?
    Posted Dec 11, 2013 10:05 PM
    Yes they are on the same cluster ...
    7 - IAP-105's - Connected to a Comcast Business Class Modem On a 8-Port 10/100Mbps PoE Switch - TPE-S80
    Yes .. But What Happens when the " Controller IAP" In This Case 1-West Changes to 2-West ?
    Will It Use The 1-West Configuration  ?  Or The 2-West Configuration ?
    In My Case Shouldn't All Configurations Be The Same ?
  • 5.  RE: DHCP - Just noticed a weird thing ?
    Posted Dec 12, 2013 08:31 AM
    It will use whatever the config is on the Master/VC of 2-West , unless that one takes over as the Master/VC
  • 6.  RE: DHCP - Just noticed a weird thing ?
    Posted Dec 12, 2013 10:57 AM
    I am Sorry .. I am not sure I understand your response ...
    I would like ALL IAP-105's to have the same configuration - 192.16810.0 ..
    So if the ( MAIN / Controller / 1-West ) happens to go down
    That 2-6 would use the 192.16810.0 - Not the 172.31.98.0
    Sorry .. Not sure I am explaining it correctly ..
