DHCP NAK packets
  • 1.  DHCP NAK packets
    Posted May 25, 2016 11:26 AM
    Hi Guys,
    IAP configured with simple SSID Guest primary usage. for the VLAn Network assigned - default. Palo Alto firewall configured as DHCP Server range is 10.240.31.220 - 10.240.31.240. IAP IP address is 10.240.31.243.
    When the client connection to the IAP it gets a completely different IP address. PCAP from the Palo Alto attached and a screen shot of the IAP. This is driving me mad
    Cheers,
    Mykhaylo
  • 2.  RE: DHCP NAK packets
    Posted May 25, 2016 11:37 AM
    It looks like you have two DHCP servers:  10.240.31.254 and 192.168.10.1
    You need to resolve that.
  • 3.  RE: DHCP NAK packets
    Posted May 25, 2016 12:05 PM
    Hi Colin,
    Sorted. had another DHCP server configured on Juniper SRX box. Removed and everything is working as it should
    Cheers
