Greetings,
I'm trying to set up the dhcp options for our aruba controllers and access points. We are using a Mitel 3300 controller for dhcp since we are putting the wireless hardware on our voip vlan. Since the devices need option 43 and 60 the Mitel controller only has option 43, do the access points absolutely need option 60?
Yes, it needs both, because a number of manufacturers use both options and they need to know when to use or ignore them, by configuring both.
Why don't you use dns (aruba-master.domain.com) for discovery instead.
