AOS-CX Switch Simulator
DHCP Pool creation
This thread has been viewed 66 times
  • 1.  DHCP Pool creation
    Posted May 27, 2021 02:02 PM
    I need help regarding Pool creation in HP Aruba 8360 sw. I created a pool vlan4. But when I try to create another pool vlan7 i am getting this message
    CoreSW(config-dhcp-server)# pool vlan13
    DHCP server instance for VRF default is enabled. Retry after disabling it.
    How i can proceed with it.
    Regards
    Adnan Khan
  • 2.  RE: DHCP Pool creation
    Posted May 27, 2021 02:59 PM
    dhcp-server vrf default
     enable
     pool test1
       range 1.1.1.10 1.1.1.20
    switch(config)# dhcp-server vrf default
    switch(config-dhcp-server)# pool test2
    switch(config-dhcp-server)# disable
    switch(config-dhcp-server-pool)#
    DWan
  • 3.  RE: DHCP Pool creation
    Posted May 27, 2021 03:12 PM
    Hi @DWan
    Got it. now its work. Appreciate your help.
    Adnan Khan
  • 4.  RE: DHCP Pool creation
    Posted Nov 24, 2021 07:48 PM
    https://www.networktasks.co.uk/environments/hp/provision/dhcp-server-on-hpe-aruba-switch
    Wanna ask whether that "dhcp-server disable" is mandatory for
    every ArubaOS switches
    or
    only on certain model or certain version
    AFAIK other brand simply changes without need to disable dhcp first.
    Correct me if I am wrong
    Disable dhcp server will disturb service momentarily
    tq
    Nawir Bunai
  • 5.  RE: DHCP Pool creation
    Posted Nov 25, 2021 05:52 AM
    If you copy/paste the commands, the interruption is very minimal, would expect less than a second, and DHCP will retry if it doesn't get a response.
    You can see this as a 'safe guard' as well, because it prevents you from making changes to an operational service and potentially introducing an issue. It looks to me carefully designed like this, and you could ask the other vendors that you know that don't, why they haven't.
    An alternative solution is to use DHCP relay (ip-helper) instead of doing DHCP server on your switches. Centralized DHCP provides better visibility and control over the clients and removes 'micro management' on each of your switches, and resolves the redundancy issues that you have with local DHCP servers. And you probably never need to change the settings on the switch anymore.
