DHCP pools in W650
  • 1.  DHCP pools in W650
    Posted Feb 16, 2015 07:33 AM
    Homany DHCP pools can be created in W650.
    when i am trying to create 3rd DHCP pool in the controller, i am getting error. mentioned below
    Error processing command:ip dhcp pool "ssidemp" network 172.18.10.0 255.255.255.0 >> Failed to add pool ssidemp which has 253 addresses. Maximum addresses configurable is 512. Currently configured are 505 addresses. You may want to exclude unused address ranges.
  • 2.  RE: DHCP pools in W650
    Posted Feb 16, 2015 07:41 AM
    If it is a /24, only two for the internal DHCP server.  There is a limit of 512 addresses that can be configured using the internal DHCP server.
  • 3.  RE: DHCP pools in W650
    Posted Feb 16, 2015 08:31 AM
    Thank you Joseph, I met my task by configuring 3,  /25 networks.
