DHCP problems on version 8.0.1
  • 1.  DHCP problems on version 8.0.1
    Posted Jan 27, 2017 06:59 AM
    Hello
    I have been trying to migrate our working config from version 6.5.x.x to AOS 8.0.1 in a virtual MM and a spare controller. We did not use the migration tool, as that was too limited in how we wanted our new setup to be designed.
    I cannot get external DHCP to work (the DHCP server is the same as the 6.5 is running on). Only when I use the internal DHCP does my clients (using a 335 AP) get a DHCP adresses. However, the limit of 8k adresses makes this unusable for us.
    I am getting the following log entry when I enable external DHCP:
    PAPI_Send: sendto DHCP Server failed: Connection refused Message Code 0 Sequence Num is 32310
  • 2.  RE: DHCP problems on version 8.0.1
    Posted Jan 27, 2017 07:15 AM
    Do you have in place an IP helper address pointing to your dhcp server under that layer 3 VLAN on your uplink switch ?
    Get Outlook for iOS
  • 3.  RE: DHCP problems on version 8.0.1
    Posted Jan 27, 2017 07:57 AM
    Hi Victor
    Yes, there are IP helpers configured on the controller.
    One of them is even on the same subnet as the controller itself.
    Best regards
    - Nicolai
