Dhcp query on IAP
  • 1.  Dhcp query on IAP
    Posted Oct 18, 2014 01:07 AM
    Hi all
    I have IAP 105 and I want to configure the dhcp server in IAP for the wireless users...I have configured the client IP assignment as " virtual controller assigned" .the problem I am facing is I don't see option to configure the range of IP address.
    can anyone tell me whether is it possible to specify the IP address range in dhcp scope?
    thanks in advance.
    #ALE
  • 2.  RE: Dhcp query on IAP
    Posted Oct 18, 2014 03:10 AM
    Here you go - its really simple:
    Go to System > DHCP
    Also read here: (Depands which INSTANTAP AOS version you are using)
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/IAP-105-Guest-User-DHCP-Pool/td-p/73164
  • 3.  RE: Dhcp query on IAP
    Posted Oct 20, 2014 04:56 AM
    hi
    thank you for your reply..
    I want to configure the range of IP address and which means I want to exclude the some IP address in the middle.
    how can I do that?
  • 4.  RE: Dhcp query on IAP
  • 5.  RE: Dhcp query on IAP
    Posted Oct 20, 2014 03:50 PM
    hi
    thank you for the reply..
    how about the excluding the specific IP addresses by using comma?
