DHCP relay IAP 105
  • 1.  DHCP relay IAP 105
    Posted Oct 21, 2014 10:18 AM
    Hey Everybody,
    I have a IAP 105 WiFi network with VLANS for different SSID's.
    As DHCP server we would like to use our windows domain controller which is in VLAN1.
    On the network configuration we has configured the following options on the VLAN tab.
    - Client IP Assignment - Virtual Controller Managed
    - Client VLAN assignment - Custom "WiFi-Guest (VLAN: 30"
    On the DHCP configuration we have configured this "WiFi-Guest (VLAN: 30" scope as a "Centralized, L3" scope.
    This all works fine we do get a correct IP address in the VLAN 30 subnet (192.168.30.x /24).
    But when we brose for the internet it seems that traffic is natted using the IP address of the controller itself.
    How can I use VLAN and DHCP relay without NAT?
  • 2.  RE: DHCP relay IAP 105
