Dhcp Relay on vLan Interface?
  • 1.  Dhcp Relay on vLan Interface?
    Posted May 23, 2015 11:15 PM
    Hi.
    I am trying to put dhcp relay on a new vlan. Vlan 500, but I dont know what commands to use. I already have seven vlans using it, but someone else configured the router.
    I tried: (Aruba-DataCenter-1) (vlan "500") #ip helper-address 10.1.10.20.
    And:
    (Aruba-DataCenter-1 (vlan "500") #dhcp-relay- DHCPRelay1
    But it didnt like that.
    Any help is greatly appreciated.
    Here is my show interface for vlan 500 and vlan 400
    (Aruba-DataCenter-1) #show interface-config vlan 500
    vlan "500"
    Parameter                   Value
    Interface OSPF profile      N/A
    Interface PIM profile       N/A
    Interface IGMP profile      N/A
    Directed Broadcast Enabled  Disabled
    Interface shutdown          Disabled
    mtu                         1500
    IP Address                  192.168.50.1/255.255.254.0
    IP NAT Inside               Disabled
    IPv6 Address                N/A
    IPv6 link local Address     N/A
    DHCP client                 Disabled
    DHCP relay profile          N/A
    Interface description       N/A
    (Aruba-DataCenter-1) #show interface-config vlan 400
    vlan "400"
    Parameter                   Value
    mtu                         1500
    IP Address                  192.168.40.1/255.255.254.0
    IPv6 Address                N/A
    DHCP relay profile          DHCPRelay1
  • 2.  RE: Dhcp Relay on vLan Interface?
    Posted May 23, 2015 11:18 PM
    You need to configure a DHCP relay profile and then apply the profile to the interface.
    Tim
  • 3.  RE: Dhcp Relay on vLan Interface?
    Posted May 24, 2015 10:33 AM
    Hi Tim,
    Thanks for your quick response.
    I have DHCPRelay1, as a DHCP Profile, it is applied to the other Vlans, by a consulting company. But, when I try to apply it to the vlan500 interface, it rejects it. Can you tell me what command should I be using to apply DHCPRelay1 to vlan500?
    I really appreciate your help. Clearly, training classes are in order, on my end!
  • 4.  RE: Dhcp Relay on vLan Interface?
    Posted May 24, 2015 10:43 AM
    Interface vlan 500
    Dhcp-relay-profile <PROFILE name="">
    Tim</PROFILE>
  • 5.  RE: Dhcp Relay on vLan Interface?
    Posted May 24, 2015 01:22 PM
    Tim,
    Thank you so much. Again, you helped me move forward.
