DHCP Server issues....weird
  • 1.  DHCP Server issues....weird
    Posted Nov 15, 2012 03:52 PM
    Ok, we only use the on-controller dhcp server for the guest portion of our wireless deployment, which in most cases is very small.
    We recently put in a new controller at a new site, and set up the guest ssid and catpive portal, etc, but it stopped working earlier today.  This is what I found-
    lease 172.20.0.253 {
      starts Thu Nov 15 20:33:13 2012
      ends Thu Nov 15 21:03:13 2012
      binding state active;
      next binding state free;
      hardware ethernet 38:aa:3c:f6:28:e1;
      uid "\0018\252<\366(\341";
      starts Thu Nov 15 20:33:14 2012
      ends Thu Nov 15 21:03:14 2012
      starts Thu Nov 15 20:33:15 2012
      ends Thu Nov 15 21:03:15 2012
      starts Thu Nov 15 20:33:16 2012
      ends Thu Nov 15 21:03:16 2012
      starts Thu Nov 15 20:33:17 2012
      ends Thu Nov 15 21:03:17 2012
      starts Thu Nov 15 20:33:19 2012
      ends Thu Nov 15 21:03:19 2012
      starts Thu Nov 15 20:33:20 2012
      ends Thu Nov 15 21:03:20 2012
      starts Thu Nov 15 20:33:21 2012
      ends Thu Nov 15 21:03:21 2012
      starts Thu Nov 15 20:33:22 2012
      ends Thu Nov 15 21:03:22 2012
      starts Thu Nov 15 20:33:23 2012
      ends Thu Nov 15 21:03:23 2012
      starts Thu Nov 15 20:33:24 2012
      ends Thu Nov 15 21:03:24 2012
      starts Thu Nov 15 20:33:25 2012
      ends Thu Nov 15 21:03:25 2012
      starts Thu Nov 15 20:33:27 2012
      ends Thu Nov 15 21:03:27 2012
      starts Thu Nov 15 20:33:28 2012
      ends Thu Nov 15 21:03:28 2012
     This actually would go on and on and on, several hundred entries of the same lease to the same mac.  Also I should point out that the clients never get an address.
    I restarted the dhcpd process, didn't fix it, restarted the controller, no joy, and even deleted the dhcp server settings, restarted the controller, and reconfigured the dhcp server and it didn't do anything different.
    Anyone seen this before?  It's not a huge issue at the moment but I will opening a TAC case tomorrow unless someone has a fix for it.
  • 2.  RE: DHCP Server issues....weird
    Posted Nov 15, 2012 04:31 PM
    Hummm...
    What version are you running?
    Also, can you paste/post up your DHCP and IP interface config portions please?
  • 3.  RE: DHCP Server issues....weird
    Posted Nov 15, 2012 04:47 PM
    Also if you see the output the lease start time increment to 1 sec for every entry. can you also check if the client is renewing the IP continuously. it could be because of a virus on the client. you can verify this with a wireshark capture on the client machine. or try enabline debug on the dhcp.
    #conf t logging level debuging network process dhcpd
    and check the "show log network 30" output.
  • 4.  RE: DHCP Server issues....weird
    Posted Nov 15, 2012 10:45 PM
    Well this is a really interesting issue... i have seen this but i mean not hundreds  of times... i have seen this but maybe just like repeating 10 times... and well actually didnt give me any issue but still ill be looking forward for the resolution... i would like to know what code version you got? it is an old 3.x.x.x version?
  • 5.  RE: DHCP Server issues....weird
    Posted Nov 16, 2012 03:18 AM
    Other thing which might help you is, assuming it's a normal person with a malfunctioning client device, handy to know it's a Samsung one (OUI check). Or at least has a Samsung NIC.
    Assuming the client is wireless rather than wired, why not look at him on the client list and blacklist him to test?
    Knowing who it is will help a lot.
  • 6.  RE: DHCP Server issues....weird
    Posted Nov 21, 2012 10:56 AM
    Sorry for the lack of responses, was busy working on higher priority items.
    It's actually several clients, not just one MAC that has the issue or the repeated leases.
    It goes on and on until eventually the dhcp server just freezes up and no clients can get on anymore.  I clear the bindings and restart the process to get it going again but that is definitely not a good long term solution.  Luckily most people on this particular SSID are just there for 30 minutes or less.
  • 7.  RE: DHCP Server issues....weird
    Posted Nov 21, 2012 11:46 AM
    What code version you got? maybe it could be a bug...
  • 8.  RE: DHCP Server issues....weird
    Posted Nov 26, 2012 02:55 PM
    6.1.3.4
  • 9.  RE: DHCP Server issues....weird
    Posted Jan 17, 2013 12:20 PM
    I have a customer running 5.0.4.8 on a 3200 that is experiencing the same issue with a client, though it only seems to be happening to a single client.  Client is a Apple device.
    Anyone have a fix for this?
  • 10.  RE: DHCP Server issues....weird
    Posted Jan 17, 2013 04:40 PM
    Weird,  the clients attempts dried up, now i only see 2 leases in the controllers dhcp server for them.
    Maybe its just a client issue?
