DHCP Server on 6.3.1.5
  • 1.  DHCP Server on 6.3.1.5
    Posted May 29, 2014 06:47 AM
    i have add an eclusion IP range to my dhcp server on the controller, but when i try to remove it, i receive this error:
    "Failed to remove. Maximum DHCP address limit of 256 hit. You may want to exclude unused address ranges."
    Can you explain how i can remove now the excluded range?
    i have tryed also by SSH without success.
    best regards
    Andrea Acampa
  • 2.  RE: DHCP Server on 6.3.1.5
    Posted May 29, 2014 08:22 AM
    Starting in version 6.3, maximum DHCP lease amounts are enforced.   It sounds as though that removing that exclusion will go above the 256 threshold.  I assume you have a 620 controller?  See the following table for the limits of each platform from the 6.3 release notes.
