DHCP server on wireless not working
This thread has been viewed 23 times
  • 1.  DHCP server on wireless not working
    Posted Oct 30, 2014 08:27 AM
    I'm trying to set up a DHCP Server linked to a wireless connection, the server is up, but when a client authenticates to the same server SSID, the client is unable to get an ip.
    Seems like the controller doesn't send DHCP DISCOVER messages from the client to the server in the same SSID.
    I have reviewed both Broadcast supression at VAP, also wireless client communication  is allowed.
    I have checked that client can authenticate, but once it does, it can't get ip from DHCP.
    Someone can help me about this issue??
  • 2.  RE: DHCP server on wireless not working
    Posted Oct 30, 2014 08:39 AM
    Please share the role details for the client.    Find out what role the client is in after connecting (show user).  Then issue a show rights <name-of-role> to view that policies are set and to ensure DHCP is allowed.
    Also, is the VLAN that the user is being put onto a VLAN trunked on the controller?    Do you have/need IP Helpers for the DHCP server?
    To troubleshoot the DHCP request, enable DHCP debugging and view the logs:
    config t
    logging level debugging network subcat dhcp
    show log network | include <mac-of-client>
    Disable debugging when done:
    no logging level debugging network subcat dhcp
  • 3.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 06:47 AM
    It's very strange, the wireless client authenticates, don't get ip and the controller says there is no user.
    Attached you have the logs, the user is umhnet\jramon, the wireless client mac is 00:1c:bf:82:aa:25
    Thank you
    Attachment(s)
    txt
    logs.txt   44 KB 1 version
  • 4.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 07:23 AM
    jgarciav,
    what is the output of "show station-table | include 00:1c:bf:82:aa:25"
    Is this the only device that cannot get an ip address on VLAN 102?
    What are the ACLs in the role "corporativo"?  Does the role corporativo have a VLAN in it?
    Type "show rights corporativo" and give us the output.
  • 5.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 07:41 AM
    Any device can get ip address, we connect to SSID linked to vlan 100 not 102.
    Role corporativo doesn't have Vlan attached to it, it's SSID "congreso" which is linked to Vlan 100.
    For clarification, the DHCP server is one laptop also connected by wireless to SSID "congreso" and whithout DHCP, it has the manual ip configured, we try to get ips from this DHCP for wireless clients also connected to SSID "congreso".
    Both clients and DHCP server are in the air, all connected to SSID "congreso".
    Here you have the commands:
    (aruba_master) #show station-table | include 00:1c:bf:82:aa:25
    00:1c:bf:82:aa:25 umhnet\jramon corporativo 00:00:01 Yes ap-E06.1.04_sw10.102_p0/46 congreso g No aaa_perfil_dot1x
    (aruba_master) #show rights corporativo
    Derived Role = 'corporativo'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Periodic reauthentication: Disabled
    ACL Number = 68/0
    Max Sessions = 65535
    access-list List
    Position Name Type Location
    1 denegar_acceso_aruba session
    2 permitir_dhcp session
    3 allowall session
    Priority Source Destination Service Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6
    1 192.168.18.6 any any permit Low 4
    2 192.168.18.5 any any permit Low 4
    3 192.168.133.4 any any permit Low 4
    4 any direcciones aruba any deny Yes Low Yes 4
    permitir_dhcp
    1 any any svc-dhcp permit Low 4
    allowall
    1 any any any permit Low 4
    Expired Policies (due to time constraints) = 0
    (aruba_master) #
  • 6.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 07:45 AM
    Put the "allowall" acl to the top of corporativo and try again.
    You have a laptop providing DHCP?
  • 7.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 07:54 AM
    Hi again
    I have tried but still don't get ip.
    ACL Number = 68/0
    access-list List
    1 allowall session
    2 denegar_acceso_aruba session
    3 permitir_dhcp session
    allowall
    permitir_dhcp
    Yes, I have a laptop connected by wireless as DHCP server, and others laptops connected to the same SSID as clients.
    It's worth mention that VLAN 100 has an external router as default gateway, then if I configure a dhcp helper at the router  (ip helper address ) with the DHCP ip then the others laptops get ip.
    I mean, the DHCP DISCOVER packet is going out the controller to the external router, then it converts it from broadcast to unicast and send it to DHCP, then the client can get ip.
    Thank you
  • 8.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 08:03 AM
    If your dhcp server is wireless, I might not be able to help you, because that is not a scenario we encounter.
  • 9.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 08:39 AM
    You mention the DHCP laptop is also wireless; when you do a show user on the controller, is that laptop in the same role as the client or a different role?   Also, have you doublechecked that the DHCP service on the laptop is bound to the proper interface (listening on the Wi-Fi interface)?
  • 10.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 10:40 AM
    Laptop is in the same role as client, both of them are in "corporativo" role.
    Yes, rhe dhcp server is bound to wireless adapter.
  • 11.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 10:47 AM
    The question is that it seems like the controller don't send the Discover broadcast back to the same gre tunnel to the AP where both the dhcp server and the client are associate.
    Also, I don't know why the client is authenticated but don't appear as valid with its role.
  • 12.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:12 AM
    Jgarciav,
    Imagine if a wireless client started serving up dhcp addresses to your users....
    Let me check to see if that was removed...
  • 13.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:29 AM
    Hi joseph,
    The purpose of setting up a wireless dhcp server is just test some configuration like deny udp 68 in acl or some firewall configuration to deny or avoid having a dhcp server on the air. This is why I'm trying to make this lab, to have a valid config to avoid it, even the case some valid wireless client has the idea to damage our network.
    Please if you confirm me that Discover dhcp can't be sent to wireless let me know
    Thank you
  • 14.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:31 AM
    jgarciav,
    What version of ArubaOS is this?
  • 15.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:43 AM
    6.3.1.3
  • 16.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:44 AM
    jgarcia v,
    do you have "drop broadcast and multicast" disabled on the Virtual AP profile?
  • 17.  RE: DHCP server on wireless not working
    Posted Oct 31, 2014 11:46 AM
    Yes, both options are unchecked in gui
  • 18.  RE: DHCP server on wireless not working
    Posted Nov 03, 2014 07:54 AM
    Making a sniffing on DHCP server, I can't see any DHCP DISCOVER packet when we try to get ip from client.
    Is there some way to see if packets are getting dropped at controller?
    Thank you
  • 19.  RE: DHCP server on wireless not working
    Posted Nov 03, 2014 07:55 AM
    What role are the users getting?
    Can you run:
    show rights <user-role-name>
  • 20.  RE: DHCP server on wireless not working
    Posted Nov 03, 2014 07:58 AM
    Attached you have the role, we also have tried with "allowall" first position
    Attachment(s)
    txt
    role.txt   2 KB 1 version
  • 21.  RE: DHCP server on wireless not working
    Posted Nov 03, 2014 03:28 PM
    I had this same exact issue with a cent os box running dhcp. It was wired to the controller however. i called aruba support and the anwser they gave me was to run dhcp on the controller. We could not figure out why the controller would not pass dhcp replies to clients. my setup was working fine for a month, and then one day the entire guest network was down. So just know this is an actual issue. I was on a 3200 controller with 6.1.0.11 I believe.
  • 22.  RE: DHCP server on wireless not working
    Posted Nov 03, 2014 04:23 PM
    This is slightly different, in this case the DHCP server is not wired to the controller but it's on the air associate to a virtual AP, the question here is that DHCP DISCOVER sent by another wireless client is not coming to the dhcp server "on the air".
    According to aruba, there is some configs guide to avoid wireless dhcp servers offering ip to clients "on the air" for example make some ALC entry like "user any udp 68 deny" just to avoid sending DHCP OFFER from server in the air to anyone, but the question is that even DHCP DISCOVER can't reach the potential wireless DHCP server.
    I don't know if someone have tested this config.
