DHCP-server is running on a 2930M using WC.16.04.0008.
When I try to put "option 60 ascii ArubaAP" in the dhcp pool, I get this error:
"DHCP-Server does not allow raw option"
How do I get this resolved?
Hi Joey,
Option 60 is not currently supported in the DHCP server feature of ArubaOS-Switch.
Product management is currently investigating with the lab adding in option 60 in ArubaOS-Switch.
In order to use ZTP, you'd need to use a Linux or Windows-based DHCP server.
DHCP server raw Option 60 is supported now in16.06.
[no] option 60 {ascii <ascii-string>|hex <hex-string>|ip <IPADDR-STR>[IP-ADDR2d… IP-ADDR8]}
Firmware 16.07.0002 is now supported option 60 already :)
