last person joined: 8 hours ago
DHCP Timeout 6.2.1.0-3.4.0.3_40346
  • 1.  DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 03:46 AM
    Hi All,
    I have recently upgraded our firmware to version 6.2.1.0-3.4.0.3_40346 but on a few of the Virtual Controllers i can see clients getting DHCP Timeout's, this has not happened on all VC but one in particular.
    Any Suggestions on what i can do to resolve this?
    Many Thanks
    Nisha
  • 2.  RE: DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 05:43 AM
    Are you using VC based DHCP (rather than network)? I assume so?
    What I would do first, is just check you're not running out of addresses? I'm not aware of a way of doing this on the IAP VC GUI, but if you SSH/Telnet to the VC, you can do "show dhcp-allocation". You'll need to count the entries I'm afriad!
    Thanks.
  • 3.  RE: DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 05:48 AM
    Hiya,
    yes i am using VC based DHCP. i will try and have a look via ssh.
    thanks
    nisha
  • 4.  RE: DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 06:13 AM
    I have done a show dhcp allocation via ssh to the VC, we have a /23 subnet so are cablet of aound 510 hosts and we only have 130 clients connected at any given time?
    any further suggestions?
    Nisha
  • 5.  RE: DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 09:33 AM
    A couple of thoughts...
    Did you go for this version/upgrade for a specific reason? There's a 3.4.0.4 and a v4 available now?
    Nothing I can see in the release notes suggests a specific fix, but it might be worth considering the newer ones?
    Other than that, I'd think you'd want to be in front of the client to debug it, as the IAP debugging is a bit limited.
    Other than that, perhaps try a reboot?
  • 6.  RE: DHCP Timeout 6.2.1.0-3.4.0.3_40346
    Posted Nov 27, 2013 03:32 PM
    I went for this firmware version because it supports 802.11ac.. is there a newer firmware version?
    i have tried rebooting a couple of times but i am still seeing a few DHCP timeouts.
