dhcpdwrap[1839]: <202513>
  • 1.  dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 02:36 PM
           I recently configured a new SSID for 802.1x with wpa2-AES and have intermittent connectivity issues across the premises. Enabled the network log and my logs are flooded with similar messages below.
    Jan 30 16:16:24  dhcpdwrap[1839]: <202513> <DBUG> |dhcpdwrap| |dhcp| Could not find interface and/or vlan for ip=192.168.5.155, could be reply to mobility message.
    May the cause for the message and will this be the root cause for the intermittent root cause issues.
  • 2.  RE: dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 04:10 PM
    @thanjavuru wrote:
    Are you using the Aruba Controller to provide DHCP?
  • 3.  RE: dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 06:46 PM
    yes I am using the DHCP on the controller.
    Please find the dhcp pool configured for the SSID ,
    ip dhcp pool GCC_Secure
     default-router 192.168.1.254
     dns-server 24.97.221.139 199.29.211.1
     lease 0 3 0 0
     network 192.168.0.0 255.255.252.0
     authoritative
  • 4.  RE: dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 06:48 PM
    What is the output of show ip dhcp statistics?
    It is not recommended to have more than 512 addresses on the internal dhcp server. More than that and an external dhcp server is required.
  • 5.  RE: dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 07:00 PM
    Hi Please find the output
    Network Name           192.168.4/22
        Free leases        551
        Active leases      395
        Expired leases     0
        Abandoned leases   0
    Network Name           192.168.0/22
        Free leases        869
        Active leases      70
        Expired leases     0
        Abandoned leases   0
    May i know what the error or log message meant for? Is this will create intermittent connectivity issues, that is an user has to try three to four times before he gets connected . this issue is seen randomly.
  • 6.  RE: dhcpdwrap[1839]: <202513>
    Posted Feb 07, 2012 07:02 PM
    The truth is that the internal DHCP server is not meant to serve anything more than a small guest network.  You should use an external DHCP server for better performance and to ensure you do not have any interruptions.  The DHCP daemon simply does not run at a high priority in the controller and that will not change any time soon.
    Get that external DHCP server as soon as possible.
