difference between cli and web interface
  • 1.  difference between cli and web interface
    Posted Dec 12, 2018 07:28 AM
    Hi
    I found variance between CLI output and Web interface, I'm already sure that's not diplsay delay on web interface.
    Typically the "show ap database" command show me some AP that i cannot found on the menu "Monitoring -> Network -> all access point" in web interface (on master controller).
    The controller run 6.3.1.25 AOS version.
    Does anyone already encouter such differences ?
    Does this bug already been discovered / patched ?
    Regards
  • 2.  RE: difference between cli and web interface
    MVP EXPERT
    Posted Dec 12, 2018 08:32 AM
    AOS 6.3 is quite an old release now so there is a good chance if it is a bug it has already been patched. Are you running this from within a Master/Local environment?
  • 3.  RE: difference between cli and web interface
    Posted Dec 13, 2018 03:48 AM
    Yes this bug have been seen in Master/Local environment.
