Difference between controller-less Instant APs and controller-based APs
  • 1.  Difference between controller-less Instant APs and controller-based APs
    Posted Mar 08, 2017 09:49 AM
    Hi guys,
    I would like to know the main differences/advantages of the controller-based APs upon the controller-less flavour of Instant APs. Do they have more features? Do they  provide better performance? If I have a good WLAN with controller-less APs, why should I consider to move to a controller-based AP architecture?
    Julián
  • 2.  RE: Difference between controller-less Instant APs and controller-based APs
    MVP EXPERT
    Posted Mar 08, 2017 12:47 PM
    Hey, take a look at the below forum post. It has been discussed quite a bit at length. Any other questions, just go ahead and ask :)
    https://community.arubanetworks.com/t5/Wireless-Access/Controller-vs-IAP/m-p/67732
  • 3.  RE: Difference between controller-less Instant APs and controller-based APs
    MVP EXPERT
    Posted Nov 14, 2019 11:01 AM
