Difference between instant and normal
  • 1.  Difference between instant and normal
    Posted Feb 13, 2019 02:48 AM
    Could you please tell me someone the difference between the instant APs and the normal?
    For example the 305 AP has two models. instant and non instant.
    Kostas
  • 2.  RE: Difference between instant and normal
    MVP EXPERT
    Posted Feb 13, 2019 04:03 AM
    An Instant can function as a controller-less AP (i.e a Virtual Controller that resides on the AP) or terminated on a physical or Virtual Controller (that resides in a VM environment) if converted.
    A "standard" AP will only terminate on a physical or Virtual Controller (that resides in a VM environment) and cannot be converted to an Instant.
    A unified AP is the new standard moving forwards where both APs can act in either Instant or regular.
    https://blogs.arubanetworks.com/solutions/aruba-unified-ap-platform/
  • 3.  RE: Difference between instant and normal
    Posted Feb 13, 2019 05:19 AM
    Thanks for your reply. And a final question please:
    What is the role and the difference between:
    Aruba Central DM 1 Token 3y Sub E-STU
    Aruba Central Svc 1 Token 3y Sub E-STU
  • 4.  RE: Difference between instant and normal
    MVP EXPERT
    Posted Feb 13, 2019 05:22 AM
    One is a device management license (DM) and the other is a services license
    (svc) eg for Guest, Clarity or Analytics etc.
  • 5.  RE: Difference between instant and normal
    Posted Feb 13, 2019 05:42 AM
    So, to understand better:
    For every device I buy, it's necessary to add in my cart a licence for device management and a licence for services. right?
  • 6.  RE: Difference between instant and normal
    MVP EXPERT
    Posted Feb 13, 2019 05:49 AM
    You'll need a DM for every IAP or Switch you with to manage at a minimum. For any additional services you will need a services license.
