Difference between route src-nat and src-nat?
  • 1.  Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 02:52 AM
    Hi Guys, Could someone give me the actual difference between "any any any route src-nat" and "any any any src-nat" with a usecase as to how it works in Aruba?
  • 2.  RE: Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 03:07 AM
    Hi Joe_Lee,
    Its mainly required when you are working with RAP.
    Below is the screenshot from AOS UG.
  • 3.  RE: Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 05:31 AM
    Hi SumaN, Thanks for your posting, but I think what you have posted only tells me what is src-nat and dst-nat is. However, I am keen to know more about the functionality of "any any any route src-nat" and "any any any src-nat" with a usecase along with the difference between them.
  • 4.  RE: Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 08:00 AM
    Route src-nat is specifically used in an ACL when split tunneling client traffic on a Remote AP http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Remote_AP/Split_Tunneling.htm  You would use split tunneling on an access point configured at a remote AP at a branch office so that corporate traffic gets sent back to the corporate headend and internet traffic gets sent locally to the ISP.
    Soure-NAT is configured as an ACL for a Campus AP to do NAT translation for a user's traffic on a campus:  http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/ip_access_list_session.htm?Highlight=src-nat
  • 5.  RE: Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 09:57 PM
    Hi Colin,
    Thank you for the post.
    Say for example, My split-tunnel ACL's are like this
    any any svc-dhcp permit
    any any svc-dns permit
    user controller any permit
    any any any route src-nat <<<<<<<< instead of this if I specify as "any any any src-nat", then what is going to happen to the user traffic?
    Could you please explain in detail
  • 6.  RE: Difference between route src-nat and src-nat?
    Posted Jun 23, 2015 11:59 PM
    I never tried src-nat with a split tunnel rap, but from experience, the results could be unpredictable, or just not work, at all.
  • 7.  RE: Difference between route src-nat and src-nat?
    Posted Jun 30, 2015 10:51 AM
    I think it´ll be forwarded throught he tunnel and NATed to the RAPs inner IP (taken from the central VPN pool on the controller). But I´m not sure.
    Cheers,
  • 8.  RE: Difference between route src-nat and src-nat?
    Posted Jul 30, 2016 12:38 PM
    Could there be an error in this RAP split-tunnel document?
    In the document 'src-nat' is stated for the splitting policy in stead of 'route src-nat'.
    Rgds
    Peter
  • 9.  RE: Difference between route src-nat and src-nat?
    Posted Jul 30, 2016 12:59 PM
    That is incorrect.  It should be route src-nat.
