Wired Intelligent Edge
Difference b/w tagged, untagged, no tagged
This thread has been viewed 66 times
  • 1.  Difference b/w tagged, untagged, no tagged
    Posted May 20, 2020 03:01 AM
    Hi All,
    Can someone please explain a clear difference between these below in Hpe terms, I know in cisco but as people told me terminology is bit different than other vendors.
    1. Tagged
    2. Untagged
    3. No tagged
    Also I have to assign a port to wifi, Printers and User machine. So they all will be going in as untagged or no tag.
    I have 3 vlans, 101- Wifi, 102-Printers and 103 for user machine.
    How would the configuration look like.
    Rish
  • 2.  RE: Difference b/w tagged, untagged, no tagged
    MVP GURU
    Posted May 20, 2020 03:33 AM
    Hi!
    Cisco and HPE (HP, HPE and Aruba) VLAN related terminology differs with regards to port aggregation (Cisco (IOS): EtherChannel, HPE (ProVision/ArubaOS-Switch): Trunk) and tagging (Cisco (IOS): Trunk(ing) an interface with VLAN ids, HPE(ProVision/ArubaOS-Switch): tagging/untagging a port with VLAN ids). The main source of confusion is a Cisco used network administrator creates Trunks (aggregated port) on HPE thinking he/she would create a tagged interface...which is not.
    With regards to untagged/tagged terminology a source could be this one.
    Generally Access ports/interfaces need to be configured as untagged members of a specific (only one is admitted) VLAN id. Say you have VLAN 1000 "Data" and you want to assign port 15 to it, the ArubaOS-Switch command will be:
    vlan 1000 (enter the VLAN 1000 context)
    untagged 15 (assign the port 15 the untagged membership for the VLAN context you're in).
    Viceversa to configure a port that will carry more VLAN Ids (Cisco: Trunk) supposing its purposes will be to act as an uplink/downlink port to other switch peer or to a VLAN aware server you have basically two ways:
    1. set that port (a physical port or a logical one, doesn't matter) to be concurrently an:
      1. untagged member of a VLAN id (the PVID Port VLAN ID, AKA the native VLAN id)
      2. tagged member of various other VLAN ids (as needed)
    2. set that port (a physical port or a logical one, doesn't matter) to be concurrently a tagged member of various other VLAN ids (as needed) making it "orphaned" of its untagged membership (so traffic admitted will be ONLY the one it carries VLAN tags, traffic without VLAN tag will be dropped).
    To do that (both cases) the port need to simply be untagged/tagged as needed, example:
    vlan 2000
    untagged port 15
    exit
    vlan 1000
    tagged port 15
    that way port 15 will be untagged member of VLAN 2000 and tagged member of VLAN 1000, in Cisco terms PVID = 2000 and trunk permit VLAN Ids 2000 and 1000.
    The no untagged chimes in to specify that a port can be removed from being member of VLAN 1 (Default), so when you see:
    vlan 1
    no untagged 15
    it means that port 15 is "orphaned" of VLAN id 1...but to work it needs to be at least tagged or untagged member of another VLAN Id otherwise it will not be accepted (a port can't be orphaned of any VLAN, it needs to be member of a VLAN Id - tagged or untagged - at worst).
    In the end the first source of confusion (Cisco: EtherChannel --> HPE: Port Trunking = Link Aggregation) chimes in too because, often, is needed to tag/untag an aggregated interface (Trk<x> where x is the port trunking Id)...suppose to have port 1 and 15 aggregated together by using LACP...that is:
    trunk ethernet 1,5 trk1 lacp
    so the (logical) interface you will need to manage now on is the trk1 (forget about ports 1 and 15), at this point to apply tagging/untagging the configuration is identical to those seen above:
    vlan 2000
    untagged trk1
    exit
    vlan 1000
    tagged trk1
    exit
    There is a nice Aruba presentation that explains the Aruba ArubaOS-Switch (ProVision of HP ProCurve) versus Cisco IOS here.
    More or less it's enough to start your journey with HP ProCurve / HPE Aruba switches.
    Please note that some HPE Switch series (Comware 5/7 OS driven) use Cisco terminology for VLAN related configurations (so access/trunk) but EtherChannels are called LAGs (Link Aggregation Groups).
  • 3.  RE: Difference b/w tagged, untagged, no tagged
    Posted May 20, 2020 03:39 AM
    To make it simple, Cisco usually uses Access Ports to connect to end-user devices and trunk ports to connect a switch to another switch and support multiple vlans.
    Access Ports are assigned a specific vlan from the switch side but from the end user side the device is not configured to specify a vlan. This is equivalent to specifying untagged vlan.
    So for example, you want to connect a PC to ports 1 to 2 and be part of VLAN 103, ports 3-4 will be connected to printers (VLAN 102), you can use the below
    Spoiler
    VLAN 103
      untagged 1-2
    vlan 102
     untagged 3-4
    or you can go to each port and specify that they are untagged
    Spoiler
    interface 1
      untagged vlan 103
    interface 2
      untagged vlan 103
    interface 3
     untagged vlan 102
    interface 4
     untagged vlan 102
    Cisco's Trunk ports are used to pass multiple vlans between switches (This is like 802.1Q trunk). In HPE's terminology, these are tagged vlans.  All the vlans over this link must be tagged. You can only have 1 untagged vlan (like a native vlan in Cisco terminology). So as an example, you want connect the uplink (port 24) to another switch and pass vlans 101-103 as tagged vlans and you want to use vlan 40 as native vlan (untagged)
    Spoiler
    interface 24
      untagged 40
      tagged 101-103
    Finally, no tagged simply removes the tag vlan from that specific port.
  • 4.  RE: Difference b/w tagged, untagged, no tagged
    Posted May 21, 2020 05:15 AM
    Hi Ayman,
    Thanks for your explanation though what you all have explained is pretty clear but I have got a question here. Lets say we have 2 vlans vlan 109 for Support team and vlan 113 which is for HP-Nonstop. Now on switch, port 1/3 is assigned to user in Support team well in this case vlan 109 should go as untagged while 113 should go as tagged,correct  me If I'm wrong. Similarly we have vlan 146 and 149 for wireless and guest there is a port 1/9 which connects to 146 and 149 vlan as well how do i determine which port should go as tagged and untagged. Its an aruba wireless ap running dhcp on vlan 146.
    Rish
  • 5.  RE: Difference b/w tagged, untagged, no tagged
    Posted May 21, 2020 10:38 AM
    Hi Rish,
    Here is my reply on the below request..
    "Lets say we have 2 vlans vlan 109 for Support team and vlan 113 which is for HP-Nonstop. Now on switch, port 1/3 is assigned to user in Support team well in this case vlan 109 should go as untagged while 113 should go as tagged"
    This 109 part is correct. As for vlan 113, I am not sure if you need to have tagged or untagged. In your case, if whatever your are connecting, is sending a tagged vlan then you need to configure the tagged vlan on the switch port. If it is not configured to send a vlan then you don't need to tag the port.
    As for the below request,
    "Similarly we have vlan 146 and 149 for wireless and guest there is a port 1/9 which connects to 146 and 149 vlan as well how do i determine which port should go as tagged and untagged. Its an aruba wireless ap running dhcp on vlan 146."
    What type of Aruba wireless setup do you have? Is it controller based on Unified/Instant? If it is instant, then you usually configure the port as a trunk with native vlan as untagged and you configure the other vlans as tagged since the instant AP will send tagged traffic if the SSIDs are mapped to different vlans. If it is controller based, then you usually configure port as untagged and traffic is tunneled all the way to the controller..
  • 6.  RE: Difference b/w tagged, untagged, no tagged
    Posted May 21, 2020 09:24 PM
    Hi Ayman,
    Its Aruba IAP-315 which has guest ssid and wireless ssid(for internal) both running on different vlans. Now the confusion happens due to things on avaya has different compared to Aruba. On Avaya I can see one port is in 2 vlans now I cant say which is tagged or untagged based on their commands and output I have never seen such a crap switch in my career. I need help in setting up wireless Ap with wireless and guest ssid on different vlans do you have any approach or suggestion I should follow to achieve this. For wireless we have 146vlan and 149 for guests.
    Rish
  • 7.  RE: Difference b/w tagged, untagged, no tagged
    Posted May 22, 2020 02:21 AM
    Hi Rish,
    Usually, we recommend one separate VLAN for management and two vlans for users (corporate and guest). Make sure all the ports where the IAPs are connected have the same configuration to avoid any issues..
    interface X
     untagged 50 <-- This is your management vlan
     tagged 146,149 <-- These are your wireless vlans
    In your case, it seems you are only using 2 vlans (less recommended) so it should be like this
    interface X
     untagged 146 <-- This is your management vlan & corporate wireless
     tagged 149 <-- These is your guest wireless vlan
    I recommend you check the Avaya user guide to understand how to configure vlans at their end.
    If you have doubt regarding the untagged vlan, you can confirm which vlan is configured as untagged as follows. You can connect your laptop to that port and check from which IP subnet do you get an IP. If the native vlan (untagged) is set to 146, you should be getting from that subnet.
