Different AP equipment firmware version
  • 1.  Different AP equipment firmware version
    Posted Nov 02, 2021 02:10 PM
    Good Morning
    I have two different Access Point, 1. aruba IAP 207 RW 2. aruba IAP 535 RW, Aruba 207 is the master and have firmware version 8.3.0.5 and Aruba 535 have firmware version 8.7.X.X, when i try to update firmware, it display a message that say: "Image Check Encountered unknown error", i need help but i dont know what to do, i have others AP 305 RW, i see too the certificate is over.
    I want to know what to do, help me.
    Wilmer Ramos
  • 2.  RE: Different AP equipment firmware version
    Posted Nov 02, 2021 06:15 PM
    you need to upgrade the AP-535 to the same firmware version as that of AP-207.
    go to ASP and download the relevant firmware and then upgrade AP-535
    https://asp.arubanetworks.com/
  • 3.  RE: Different AP equipment firmware version
    Posted Nov 02, 2021 07:50 PM
    IAP 535 have a newer version than IAP 207, i found the way to upgrade it.
    Wilmer Ramos
  • 4.  RE: Different AP equipment firmware version
    Posted Nov 02, 2021 08:09 PM
    thats great then.
