Different between 7000 series Cloud Service controller VS 7200 series Mobility controller
  • 1.  Different between 7000 series Cloud Service controller VS 7200 series Mobility controller
    Posted Feb 27, 2016 12:12 PM
    can you please clear my doubt
    what is the major different  between 7000 series Cloud Service controller VS 7200 series Mobility controller.
    what is pros & con between them ?
    Cloud Service Controller means it can not me Master ? does it requires Master Controller ?
    i'm bit confusing these term,  Cloud service & mobility controller.
    thanks
    Regard Tej Bahadur
  • 2.  RE: Different between 7000 series Cloud Service controller VS 7200 series Mobility controller
    Posted Feb 27, 2016 12:33 PM
    We do not encourage the cloud services controllers to be masters and manage other controllers, because they are not designed to be master controllers.
    Comparison is here:  http://www.arubanetworks.com/products/networking/controllers/compare/#19993,19972
  • 3.  RE: Different between 7000 series Cloud Service controller VS 7200 series Mobility controller
    Posted Feb 27, 2016 12:40 PM
    thanks for quicks reply
    by the way i have small office need to install around 20 AP, can i use 7010 COntroller to manage those 20 AP ?
    there is only one controller, if i install 7010 Cloud service controller still i can get all the feature that has 7200 series controller.  i'm aware cloud service controller has limitation max AP support, apart from that any different ?
    thanks.
    Regard
    Tej Bahadur
  • 4.  RE: Different between 7000 series Cloud Service controller VS 7200 series Mobility controller
    Posted Feb 27, 2016 03:33 PM
    The 7000 and 7200 controller have feature parity as it pertains to managing APs. However, the 7000s do things that the 7200s do not, and the 7200s do things that the 7000s do not. So you would need to identify what features outside of AP management you may require (ala if you need dual-WAN support, the 7000s are your only option, if you need to manage multiple controllers, the 7200s are what is recommended).
