Different between Activation and Aruba Central
  • 1.  Different between Activation and Aruba Central
    Posted Apr 02, 2016 01:11 AM
    Hi Guys,
    What is the different between Aruba Activate and Aruba Central?
    From the user guide, it seems like having the same function.
    There are both cloud based, and both can provision ap, and both can send the IAP a configuration.
    From my opnion, the only different is Aruba Activate works for all kind of APs (IAP, CAP, RAP),
    but Aruba Central only works for IAP, am I right?
    Please some one tell me.
    Joe
    2016.4.2
  • 2.  RE: Different between Activation and Aruba Central
    Posted Apr 02, 2016 01:14 AM
    Activate is a provisioning tool. Central is cloud based management.
    Sent from Nine<>
  • 3.  RE: Different between Activation and Aruba Central
    Posted Apr 02, 2016 01:40 AM
    Could you provide more details, please?
    I don't get you, is that mean Aruba Activate only provision AP, can not config AP, right?
  • 4.  RE: Different between Activation and Aruba Central
    Posted Apr 02, 2016 01:42 AM
    Activate is used for zero touch provisioning of controllers, APs and switches. It is a free solution.
    Central is a paid, cloud-based configuration and monitoring tool for IAPs and switches.
    Sent from Nine<>
  • 5.  RE: Different between Activation and Aruba Central
    Posted Apr 02, 2016 02:11 AM
    Thanks, I got it this time.
