Different between IAP and AP
  • 1.  Different between IAP and AP
    Posted Mar 05, 2015 08:14 AM
    How is different features between IAP and AP or
    Do you have some materials for compare feature ?
    And i want to know when i want to use AIRWAVE integrate with IAP, AIRWAVE is software or hardware and how i install airwave
    Thank you
  • 2.  RE: Different between IAP and AP
    Posted Mar 05, 2015 11:43 AM
    iap is a controller less platform and APs require a dedicated controller.
    airwave is a software that can be installed on a dedicated server, VM or you can purchase the Airwave appliance
  • 3.  RE: Different between IAP and AP
    Posted Mar 05, 2015 08:54 PM
    and how about feature ?
  • 4.  RE: Different between IAP and AP
    Posted Mar 05, 2015 09:30 PM
