Different controller on same network
  • 1.  Different controller on same network
    Posted Jul 27, 2016 05:26 AM
    Network with Aruba 7030 Controller Can we add a smaller controller to the same network say 7005, will it be managed centrally by a single console
  • 2.  RE: Different controller on same network
    MVP
    Posted Jul 27, 2016 05:57 AM
    Yes, you can configure oen controller as master and the othe as local for example.
    Then all operational configuration must be doen on the master controller and will be synced to the local.
    With this seytup you can use the capacity of both your controllers.
  • 3.  RE: Different controller on same network
    Posted Jul 27, 2016 09:05 AM
    You should also be able to use Airwave if you want to keep both controllers standalone or masters
