I have main site M & satellite site S, linked via 100Mb leased line
All VLAN routing is done by Comware based core on site M
DHCP is supplied from a server in site M
In satellite site S I have HP Procurve 2930F-48G-PoE+-4SFP+ JL256A with no IP assigned to below VLANs
In site S I have some devices (IPCams) attached to above 2930F in VLAN26 as well as a recording server in VLAN9
At the moment (I think) all the recordings travel the leased line twice, up to default gateway of VLAN26 (on core) and back on VLAN9 to the server
What would be the easiest way to make the devices (IPCams) go to the server direct (as they are oin the same switch)
Some static routes per device, do local routing on 2930F?
I am sure it is simple, I just can't see it
That is info from server (accessing the IPCam), both on same 2930F switch
PS C:\> ping 10.10.26.11
Pinging 10.10.26.11 with 32 bytes of data:
Reply from 10.10.26.11: bytes=32 time=21ms TTL=63
Reply from 10.10.26.11: bytes=32 time=2ms TTL=63
Reply from 10.10.26.11: bytes=32 time=1ms TTL=63
Ping statistics for 10.10.26.11:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 21ms, Average = 6ms
PS C:\> tracert 10.10.26.11
Tracing route to swpool-entrance.domain.local [10.10.26.11]
over a maximum of 30 hops:
1 * * * Request timed out.
2 4 ms 7 ms 4 ms swpool-entrance.domain.local [10.10.26.11]
Trace complete.
PS C:\> route print
Interface List
4...24 6e 96 ca 4c 9c ......Intel(R) Ethernet 10G 4P X710/I350 rNDC
16...24 6e 96 ca 4c 9e ......Intel(R) Ethernet 10G X710 rNDC
3...24 6e 96 ca 4c bc ......Microsoft Network Adapter Multiplexor Driver
1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.10.9.254 10.10.9.8 276
10.10.9.0 255.255.255.0 On-link 10.10.9.8 276
10.10.9.8 255.255.255.255 On-link 10.10.9.8 276
10.10.9.255 255.255.255.255 On-link 10.10.9.8 276
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 10.10.9.8 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 10.10.9.8 276
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 10.10.9.254 Default
Seb
#Aruba#Switch_Router_Interconnect
