Force 5GHz doesn't "turn off" 2.4GHz - it just pushes supported clients over to 5GHz when it can.
You can SSH to the virtual controller - you don't need a console cable for accessing the CLI.
ACNSA | ACEA | ACCP | ACMP
Original Message:
Sent: Sep 19, 2022 11:05 PM
Subject: different SSID (network) for each 2.4 GHz and 5Ghz
Despite the fact that I have Force 5GHz enabled, my newly created network broadcasts on 2.4GHz. How can I make a new network (SSID) just for the 5GHz band? Or how do I enable 5GHz in Aruba 555?
I appreciate any help you may give in advance.
Maloni
