I'm trying to figure out if it's possible to assign wireless clients to a a specific vlan based on the SSID they're using to connect.
We have a network that's split up into several VLAN's. For example, we have vlan10 for backoffice end devices, vlan30 for production devices, vlan40 for printers, etc ...
There isn't a segregation between clients based on ap's. So on AP01 there are clients that should go in vlan 30 and 40. On AP02 there are clients that belong in vlan's 10 and 40 and so forth.
The access points themselves reside in VLAN50 (configured on the PoE switches they're connected to).
The VLAN's are configured in the Network > VLAN ID section. I've made a test SSID, attached it to an AP group and set a VLAN on it. However, when I connect a client to this SSID it get's and IP from VLAN50 instead of the VLAN configured in
Configuration > AP Group > Edit "APGROUP. What am I missing to make this work?
There's one port on the Aruba controller connected to my backbone switch. This port is configured to be a trunk port on both ends and I can ping all vlan's from the Mobility controller.
