Differentiate two web login authentication
  • 1.  Differentiate two web login authentication
    Posted Jul 28, 2014 05:10 PM
    I have a Clearpass 6.3.4.64924 and I'm making modifications on two web login pages I'm using. Both are used as Captive Portal for guest or employes personal device registration.
    I ran into a road block after modifying the second web login: when I change the login method to Server-initiated, the WEBAUTH authentication is used the service from the other web login (that I don't want). So here is how it is setup:
    Web Login #1: Employes device
    Vendor: Aruba Networks
    Login Method: Server-initiated
    Authentication: Credentials
    Pre-Auth Check: Radius
    Web Login #2: Guest
    Login Method: Controller-initated
    Authentication: Crendentials
    So, web login #1 works fine, the radius and webauth requests goes through. Web login #2 is working in the controller-initiated mode, but as soon as I change it to server-initiated, the initial radius request goes through without a problem, but the webauth request doesn't work because it use the web login #1 webauth service. I've tried to find what string I have to put in the service rule to differentiate both requests, but it seems there is none.
    Is someone has already seen this issue? Unfortunately, I cannot use the same service for both system as I don't want to mix corporate stuff with guest. Let me know if you need more information.
    Thank you
    Jo
  • 2.  RE: Differentiate two web login authentication
    Posted Jul 28, 2014 05:20 PM
    I understand you dont want to use the same service but you create a enforcement policy that actually has a logic for both and that shouldn't conflict with either setup
  • 3.  RE: Differentiate two web login authentication
    Posted Jul 28, 2014 05:34 PM
    You should receive the name of the registration page in the RADIUS input tan in ClearPass. You can key off that.
  • 4.  RE: Differentiate two web login authentication
    Posted Jul 28, 2014 05:50 PM
    Hi Cappalli,
    thank you for your quick reply. Currently, my problem is not at the radius request, but the webauth request the web login is doing. If there would be the same kind of key as the radius request (Radius:Aruba:Aruba-Port-ID), that would solve my problem. Here are the computed attributes a webauth request has:
    Authentication:Full-Usernameusername
    Authentication:Full-Username-Normalizedusername
    Authentication:PostureUnknown
    Authentication:SourceAuth source
    Authentication:StatusUser
    Authentication:Usernameusername
    Authorization:SourcesAutho source
    Connection:Client-IP-Address192.168.0.x
    Connection:Client-Mac-Address000000000000
    Connection:Client-Mac-Address-Colon00:00:00:00:00:00
    Connection:Client-Mac-Address-Dot0000.0000.0000
    Connection:Client-Mac-Address-Hyphen00-00-00-00-00-00
    Connection:Client-Mac-Address-NoDelim000000000000
    Connection:Client-Mac-VendorApple
    Connection:ProtocolWEBAUTH
    Connection:Src-IP-Address127.0.0.1
    Date:Date-of-Year2014-07-28
    Date:Date-Time2014-07-28 12:41:41
    Date:Day-of-WeekMonday
    Date:Time-of-Day12:41:41
    Endpoint:Rolesome role
    Endpoint:Usernameusername
    Host:CheckTypeAuthentication
    Thank you
    Jo
  • 5.  RE: Differentiate two web login authentication
    Posted Aug 01, 2014 06:25 PM
    I think the solution here is to go by the Connection:Client-IP-Address. So you will have to make sure your clients end up on different VLANS/Subnets When they use the WebAuth.  I never did see the Page name but I might not have something set correctly.
  • 6.  RE: Differentiate two web login authentication
    Posted Aug 05, 2014 12:25 PM
    Hi sdr53,
    yeah, that could be an idea. I would still prefer to filter by page name but this is possible.
    I will be opening a TAC ticket, will reply whith their answer.
    Jo
  • 7.  RE: Differentiate two web login authentication
    Posted Aug 05, 2014 03:48 PM
    So doing something like this didn't work for you?
  • 8.  RE: Differentiate two web login authentication
    Posted Aug 13, 2014 06:09 PM
    Hi Cappalli,
    sorry for the delay. Unfortunately, that doesn't work because it doesn't apply to a webauth, but for an application authentication service. If you setup a web login with authentication credentials and pre-auth check app auth, the first authentication request will be an app authentication, the one you describe bellow with the rules. The second would be the webauth authentication that is where my problem is. This is the options I have when I setup a service in web auth:
    I've contacted TAC and they weren't able to give me an answer for that. They have also recommended I use this specific web login in controller initiated mode as it's for guest with MAC caching ( I had some issues with it that they have helped me to resolved).
    Anyway, still a mystery. Will continue to figure out a way to do it, but at least my guest login is not working as expected.
    Thx everyone :)
  • 9.  RE: Differentiate two web login authentication
    Posted Aug 13, 2014 06:24 PM
    Thanks for Sharing your responce,
    I had to use Web-auth because of the On-guard intergration with CPPM Guest. I don't have the requirement of different authentcation sources. Hopefully you will find a Work-around for what you are trying to acomplish and hopefully its not too complicated.
  • 10.  RE: Differentiate two web login authentication
    Posted Jul 28, 2014 05:44 PM
    Hi Victorfabian,
    thank you for your quick reply. I would really want to be able to differentiate them from the web login portal used (as other type of authentication will do), so I don't have to rely on what authentication source or other information.
    Maybe I'm been too strict in my design, but I really want to seperate corporate stuff and guest.
    Thank you
    Jo
