Dimensions rack mount kit AP-130-MNT-W2
  • 1.  Dimensions rack mount kit AP-130-MNT-W2
    Posted Feb 12, 2013 07:34 AM
    I have 700 AP135 to install, i would like to prepare the project before having the AP and Mounting kit.
    The document Aruba AP-130-MNT-W2 installation guide has some informations (how to install it) but have no information about dimension.
    someone has it  (HxWxD) ?
    regards
    Jerome
  • 2.  RE: Dimensions rack mount kit AP-130-MNT-W2
    Posted Feb 12, 2013 07:45 AM
    Only info i found for you  is regarding the AP unit itself..
    Hope it will help u to fit the AP/mount (usually the mount isn't much bigger in the width from the AP and it shorter in the height.
    Me.
  • 3.  RE: Dimensions rack mount kit AP-130-MNT-W2
    Posted Feb 12, 2013 08:16 AM
    thanks for your answer.
    But i will like have  the depth. I would plug a secure cable. The rj45 connector is slightly longer than  normal connector (I do not have the exact size yet) and i will be sure this cable is good for the rack mount kit.
    Jerome
  • 4.  RE: Dimensions rack mount kit AP-130-MNT-W2
    Posted Feb 12, 2013 12:52 PM
    A mechanical drawing of the AP-130-MNT-W2 box is attached (plastic part only; slider and spring not shown).
    You only have about an inch clearance behind the RJ45 connectors, which means that you'll need to use low-profile plugs to leave enough space to allow for the cable bend radius. It will be very difficult (impossible?) to use cables with the bigger molded-on RJ45 plugs; the expectation is that the cable is cut at the AP and terminated with a crimped-on plug.
    Hope that makes sense.
    /Onno
    Attachment(s)
    pdf
    AP-130-MNT-W2 plastic.pdf   80 KB 1 version
