  • 1.  Disable 2.4ghz AP125/AP135
    Posted Oct 17, 2014 11:09 AM
    I would like to test out 5ghz only on the AP125/135 we have a 3400 controller and are running 6.3 is it possibel to disable 2.4ghz how can I do this?
    Marc
    #AP125
    #AP135
    #3400
  • 2.  RE: Disable 2.4ghz AP125/AP135
    Posted Oct 17, 2014 11:13 AM
    You can disable the 2.4GHz radio or turn it into an Air Monitor under the 802.11g radio profile.
  • 3.  RE: Disable 2.4ghz AP125/AP135
    Posted Oct 17, 2014 11:23 AM
    You can also do it in the VAP profile, under allowed band setting.
    Either way, be careful, cause it will affect any other APs using these profiles.
    Alternatively, to do that on just one ap, you can apply an ap-specific profile.
