Is there a correct way to disable the 2.4GHz band for a single SSID?
Removing all the basic and transmit rates isn't allowed apparently.
Have you tried to set the RF band in the Virtual AP from all to a or g?
See, sometimes the simplest solutions are the hardest to find.
Thanks!
