Disable 2nd Ethernet Port
This thread has been viewed 49 times
  • 1.  Disable 2nd Ethernet Port
    Posted Jan 18, 2022 07:22 PM
    I am looking to administratively shut down Ethernet port 1 on the APs in my environment.
    Presently, I have the default profile assigned to the AP Group.
    With the default profile, I have the Ethernet port 1 assigned the port profile of shutdown.
    ap-group "default"
    virtual-ap "A0001_DATA_10"
    dot11a-radio-profile "default_radio_a_ui"
    dot11g-radio-profile "default_radio_g_ui"
    dot11-6GHz-radio-profile "default_radio11_ghz6_ui"
    enet1-port-profile "shutdown"
    regulatory-domain-profile "A0001_regulatory_domain"
    Unfortunately, I still cannot get Ethernet Port 1 to administratively shutdown.  See below.
    show ap port status ap-name AP_005
    AP "AP_005" Port Status (updated every 60 seconds)
    Port  MAC                Type  Forward Mode  Admin     Oper  Speed   Duplex  802.3az   802.3bz  PoE  STP  Portfast  TX-Packets  TX-Bytes   RX-Packets  RX-Bytes
    0     bc:9f:e4:ca:01:de  5G    N/A           enabled   up    1 Gb/s  full    disabled  No       N/A  N/A  N/A       1919009     664982651  2272655     336045970
    1     bc:9f:e4:ca:01:df  5G    none          enabled   up    1 Gb/s  full    disabled  No       N/A  N/A  N/A       59          11418      2133        188328
    2     be:9f:e4:ca:01:df  USB   none          disabled  down  N/A     N/A     N/A       N/A      N/A  N/A  N/A       0           0          0           0
    Any ideas on what I am missing in order to successfully shut down Ethernet Port 1?
    Thank you.
    Administrator Eronetix
  • 2.  RE: Disable 2nd Ethernet Port
    MVP EXPERT
    Posted Jan 19, 2022 05:06 AM
    Can you post the configuration of enet profile? Is the admin status indeed set to down?
    Craig Syme
  • 3.  RE: Disable 2nd Ethernet Port
    Posted Jan 19, 2022 10:14 AM
    Hi, See these screenshots.
    As you can see, there is an option for shutdown, but nothing that I can see in either the Web GUI or CLI that explicitly gives an option for administratively shutting down the 2nd Ethernet port (ETH1 in this case).
    Thank you.
  • 4.  RE: Disable 2nd Ethernet Port
    Posted Jan 19, 2022 10:50 AM
    I see the same in my lab. Can you please open a TAC case for this?
    MM (8.9.0.1) + MD7010 (8.9.0.1) + AP275
    (md7010) [MDC] #show ap port status ap-name AP275-xx:08
    AP "AP275-xx:08" Port Status (updated every 60 seconds)
    0     6c:f3:xx:xx:xx:08  GE    N/A           enabled  up    1 Gb/s  full    unsupported           N/A      N/A  N/A  N/A       1461        361466    6052        744047
    1     6c:f3:xx:xx:xx:09  GE    none          enabled  up    1 Gb/s  full    100baseTX, 1000BaseT  N/A      N/A  N/A  N/A       40          7040      34          12342​
    (md7010) [MDC] #show ap profile-usage ap-name AP275-xx:08
    AP "AP275-xx:08" Ethernet 1 Profiles
    Profile Type              Profile   Source
    AP Ethernet Link profile  default   ap wired-port-profile "shutdown" enet-link-profile
    AP LLDP Profile           default   ap wired-port-profile "shutdown" lldp-profile
    AP wired port profile     shutdown  ap-group "Test-PortShut" enet1-port-profile
    AP "AP275-xx:08" Ethernet 1 Wired AP Profiles
    Wired AP profile       default   ap wired-port-profile "shutdown" wired-ap-profile
  • 5.  RE: Disable 2nd Ethernet Port
    Posted Jan 19, 2022 10:58 AM
    Good Morning Herman,
    Will do, and thank you for confirming this in your lab environment.
  • 6.  RE: Disable 2nd Ethernet Port
    Posted Jan 19, 2022 11:36 AM
    Eronetix,
    Here's something to check. The enet1-port-profile is named "shutdown", but have you looked in that profile to confirm that the shutdown setting within that profile is actually shutdown:
    (TestController) [MDC] *#show ap wired-port-profile NoAuthWiredPort
    AP wired port profile "NoAuthWiredPort" (Predefined)
    Parameter                                   Value
    Wired AP profile                            NoAuthWiredAp
    Ethernet interface link profile             default
    AP LLDP profile                             default
    Shut down                                   No              <-----------------------------------------------
    Remote-AP Backup                            Enabled
    AAA Profile                                 NoAuthAAAProfile
    Bridge Role                                 N/A
    Time to wait for authentication to succeed  20 sec
    Spanning Tree                               Disabled
    Portfast                                    Disabled
    Portfast on trunk                           Disabled
    Loop Protect Enable                         Disabled
    Loop Detection Interval                     2
    Storm Control Broadcast                     Disabled
    Storm Control Broadcast Threshold           2000
    Auto Recovery Enable                        Disabled
    Auto Recovery Interval                      300
    Mine is NOT shutdown. Hope this helps.
    Brad
    Brad
  • 7.  RE: Disable 2nd Ethernet Port
    Posted Jan 19, 2022 05:32 PM
    Hi Brad,
    Thanks for the comments.  Yes - The profile that ETH1 is tied to is the shutdown profile.  Here is the CLI output for it:
    #show ap wired-port-profile shutdown
    AP wired port profile "shutdown" (Predefined)
    Parameter                                   Value
    Shut down                                   Yes
    AAA Profile                                 N/A
    Portfast                                    Disabled
    Auto Recovery Interval                      300​
    Unfortunately, the Ethernet port (ETH1) will still stay up with this shutdown profile applied to it.
  • 8.  RE: Disable 2nd Ethernet Port
    Posted Jan 20, 2022 04:00 AM
    This can be done per AP
    ap-name "303_H"
    enet0-port-profile "default"
    enet1-port-profile "default"
    enet2-port-profile "default"
    enet3-port-profile "default"
    #show ap port status ap-name 303_H
    AP "303_H" Port Status (updated every 60 seconds)
    0 20:4c:03:e0:b6:3c GE N/A enabled up 1 Gb/s full disabled N/A N/A N/A N/A 303916 62502106 811201 299064197
    1 20:4c:03:e0:b6:3d GE none enabled down N/A N/A N/A N/A N/A Off Off 0 0 0 0
    2 20:4c:03:e0:b6:3e GE none enabled down N/A N/A N/A N/A N/A Off Off 0 0 0 0
    3 20:4c:03:e0:b6:3f GE none enabled down N/A N/A N/A N/A disabled Off Off 0 0 0 0
    4 22:4c:03:e0:b6:3f USB none disabled down N/A N/A N/A N/A N/A Off Off 0 0 0 0
    #ap-name "303_H"
    (AP name "303_H") #enet1-port-profile "shutdown"
    (AP name "303_H") #enet2-port-profile "shutdown"
    (AP name "303_H") #enet3-port-profile "shutdown"
    (AP name "303_H") #write mem
    0 20:4c:03:e0:b6:3c GE N/A enabled up 1 Gb/s full disabled N/A N/A N/A N/A 304908 62683889 814260 299768541
    1 20:4c:03:e0:b6:3d GE none disabled down N/A N/A N/A N/A N/A Off Off 0 0 0 0
    2 20:4c:03:e0:b6:3e GE none disabled down N/A N/A N/A N/A N/A Off Off 0 0 0 0
    3 20:4c:03:e0:b6:3f GE none disabled down N/A N/A N/A N/A disabled Off Off 0 0 0 0
    I guess same should be able to achieve via ap-group.
    Predrag Jovic
  • 9.  RE: Disable 2nd Ethernet Port
    Posted Jan 20, 2022 08:55 AM
    Hi Predrag,
    Yes, I agree this can/could be done per AP.
    My desired end-state in this case is to achieve the admin shutdown of the port(s) at the ap-group level.
    I opened a case with TAC on this.  I'll add more to this thread as I get an update from them.
  • 10.  RE: Disable 2nd Ethernet Port
    Posted Jul 09, 2024 09:18 AM
    Eronetix,
    Did TAC ever have a usable response?
    Ben Wilson
