Disable 5GHz radio on IAP
This thread has been viewed 22 times
  • 1.  Disable 5GHz radio on IAP
    Posted Oct 31, 2014 04:25 AM
    Hi all,
    Is there a way to disable the 5GHz Radio in a dual-radio IAP (for example IAP-103)?
    I set only 2.4GHz band on my SSID, but I want to turn off completely the 5GHz Radio.
    Massimo
  • 2.  RE: Disable 5GHz radio on IAP
    Posted Oct 31, 2014 07:05 AM
    You can in the preferred band setting.
    Alternatively, if you only want to do that on certain APs, you can make the 5GHz radio to be a monitor as below.
  • 3.  RE: Disable 5GHz radio on IAP
    Posted Oct 31, 2014 10:20 AM
    Thanks for you reply Michael.
    I had yet set the preferred band on 2.4GHz. But this option makes the 5GHz led of my IAP Yellow, and as it is described in the IAP Installation Guide this means "5 Ghz radio enabled in non-HT WLAN mode".
    The IG says that the 5GHz Radio is disable if this led is OFF.
    I will try your latter suggestion.
  • 4.  RE: Disable 5GHz radio on IAP
    Posted Oct 31, 2014 10:24 AM
    The radios cannot be completely disabled (as in powered off).  They can only be taken out of client service as Michael mentioned.
  • 5.  RE: Disable 5GHz radio on IAP
    Posted Oct 31, 2014 10:28 AM
    Ok, thanks for yours replies Marcus and Micheal!
  • 6.  RE: Disable 5GHz radio on IAP
    Posted Oct 31, 2014 02:06 PM
    Why don't you choose which band to use from the network.
    In red, you can choose between ALL, 2.4 Ghz or 5Ghz.
  • 7.  RE: Disable 5GHz radio on IAP
    Posted Nov 03, 2014 02:42 AM
    Yes Pasquale, as I wrote in the first message I had just set this parameters. But like the others options suggested in this discussion, it doesn't d completely disable the radio.
    Massimo
  • 8.  RE: Disable 5GHz radio on IAP
    Posted Nov 03, 2014 08:04 AM
    I see. Then it would seem there is no way to completely disable.
    You can possibly post an enhancement request in order to get this feature added.
  • 9.  RE: Disable 5GHz radio on IAP
    Posted Aug 22, 2017 02:38 AM
    I have an IAP 205 which I am trying to configure. It was broadcasting the SSIDs well however after I upgraded the OS to 6.5.4 the leds of the 2.4ghz and 5ghz radios are not going green. There are always off!
    Please help!
  • 10.  RE: Disable 5GHz radio on IAP
    Posted Aug 22, 2017 09:12 AM
    Please open a separate thread as this issue is not related to the OP issue.
