disable an SSID from a particular radio
  • 1.  disable an SSID from a particular radio
    Posted Oct 17, 2012 10:36 PM
    How can I remove an SSID from a specific radio.
  • 2.  RE: disable an SSID from a particular radio
    Posted Oct 18, 2012 03:03 AM
    Well yes - you can disable a radio in the rf profile for an ap/ap group, but that will in turn effect all the ssid's defined on the specific AP or the AP group.
    John
  • 3.  RE: disable an SSID from a particular radio
    Posted Oct 18, 2012 05:54 AM
    MGeorge,
    You can do this by creating an AP-Specific Setting:
    Configuration> Wireless> AP Configuration> AP Specific.  Click New and Select that AP.  Under the Wireless LAN setting, just remove the Virtual AP that corresponds to that WLAN.
  • 4.  RE: disable an SSID from a particular radio
    Posted Dec 09, 2016 10:02 PM
    Hello Colin
    I have been tring to do this in 8.0.1.0 on a 7005 I have had success just the way you explained it in this post for prior editions. This is how I did it. But I cannot find out how to do ths in  version 8.
    I did get as far as 1 SSID and only 5g on both AP and second SSID 5g and 2.4 on both AP but I am trying to turn of the 2.4 radio on one of the AP's and I have no luck finding this.
    Thank you in advance.
    Joseph
