disable ap isolation
  • 1.  disable ap isolation
    Posted Sep 22, 2016 01:14 PM
    IAP 105 US need to disable AP isolation so Chromecast will work
  • 2.  RE: disable ap isolation
    Posted Sep 22, 2016 01:50 PM
    Is the chromecast on the same subnet as the device that you want to connect to it?
  • 3.  RE: disable ap isolation
    Posted Oct 20, 2017 11:20 AM
    I have iap 315s and looking through the chromecast AP settings, they want AP/client isolation disabled.  Where is this setting?  Also, is there a list of settings that are requried for Chromecast to work.  I have made the follwoing changes:
    Enabled: DLNA, AirGroup across mobility, domains, Guest bonjour multicast
    AirGroup Services with checks: googlecast, DIAL, DLNA Media, DLNA Print
  • 4.  RE: disable ap isolation
    Posted Aug 14, 2021 01:00 AM
    did you get this issue resolved ?
    I'm having the same issue and I can't get it my phone to cost to the google home.
    cheers
    Ian Salgado
