Disable Block Acknowledge
  • 1.  Disable Block Acknowledge
    Posted May 25, 2018 08:01 AM
    Hi!
    We are troubleshooting what we precieve are client issues on a customer site and the devicevendor want to test to Disable Block Acknowledge.
    Can´t find this in the GUI anywhere , we are using ariwave instant config.
    I´ve read it´s posible to disable on controllerbased solutions. Is it possible to disable on instant based soultions ?
  • 2.  RE: Disable Block Acknowledge
    Posted May 25, 2018 08:31 AM
    From the cli
    - configure
    - wlan ssid-profile "your-profile"
    - mpdu-agg-disable
    HTH
    Kevin
  • 3.  RE: Disable Block Acknowledge
    Posted May 25, 2018 08:34 AM
    Awesome thank you.
    Do you know if the cluster will accept cli commands when running instant config under airwave ?
  • 4.  RE: Disable Block Acknowledge
    Posted May 25, 2018 09:49 AM
    I am not completely sure, but I think that this should be done in AirWave if the VC is in "Manage Read/Write" mode
    HTH
    Kevin
  • 5.  RE: Disable Block Acknowledge
    Posted Jun 27, 2018 04:05 AM
    I took some help from TAC.
    Had to remove instant config GUI to apply cli commands. Then we ended up removing the commands since it didn't solve anything. And after that we re-enabled instant config gui.
    Thanks for the tip. Would be nice to be able to do cli / custom config even if we use instant config gui mode.
