Disable Client to Client on guest network???
  • 1.  Disable Client to Client on guest network???
    Posted Feb 22, 2012 10:19 PM
    Running Aruba Instant with 6.x latest update as of 2/22/2012
    Have an Employee Network working fine
    Have a Guest Network using Guest DMZ using built in DHCP, which properly segregates guest from employee network
     My problem is I can find a way to stop guest clients from communicating with other guest clients
    I really don’t want guest to be able to port scan other guest
    Most other AP’s I have worked with have a option to block client to client traffic on a given SID
    Any suggestions?
  • 2.  RE: Disable Client to Client on guest network???
    Posted Feb 23, 2012 02:45 AM
    How about adding an ACL in the guest role: "user user any deny" (src dst svc action)?
    user-> any user in the controller's user table
    This ACL will not let two users talk to each other.
  • 3.  RE: Disable Client to Client on guest network???
    Posted Feb 23, 2012 11:21 AM
    that may work with a controller, but i'm running Instant
    no option for Deny Any User User
    i only have {Allow:Deny} | {Service} | {to All:to a server:except a server:to a network: except a network}
    I dont want to list out each possible guest IP as a server, it would work but a lot of enteries
  • 4.  RE: Disable Client to Client on guest network???
    Posted Feb 23, 2012 02:02 PM
    mjob81,
    One way of achieving this is as follows:
    Create Network based access rules for the guest network
    Example:
    Guest network - 192.168.1.0/24
    Gateway: 192.168.1.1
    RULES:
    1.  allow any on server 192.168.1.1
    2. allow any on server <to any other server you want users to be able to access>
    3. deny any to network 192.168.1.0/24
    4. allow any to all destination
    This would prevent inter-user traffic on the guest network.
    NOTE: the above rules will not allow external sources to initiate session with the guest network clients.
    Hope it helps !
  • 5.  RE: Disable Client to Client on guest network???
    Posted Feb 23, 2012 04:41 PM
    YES that works
    In instant you cannot use xxx.xxx.xxx.0/x
    you need to use xxx.xxx.xxx.0 and 255.xxx.xxx.xxx in the subnet
  • 6.  RE: Disable Client to Client on guest network???
    Posted Mar 17, 2017 05:26 AM
    Hi Guys,
    I'm new with Aruba Controllers, My WAC series is 7220 with SW version: 6.4.3.4
    I need to do the Wireless Client isolation on my network so that the only thing each user can see is the DHCP server only.
    I did activate the option "Deny inter user traffic" on each SSID i have but still I can see other devices when using "fing" SW.
    Please I need help.
  • 7.  RE: Disable Client to Client on guest network???
    Posted Mar 17, 2017 09:06 AM
    Clients will always have access to ARP, which is what fing does.  If you have an ACL that says that those clients cannot communicate, they will be blocked from doing anything to each other.  This of course breaks down on an Open SSID where there is no encryption and clients can directly contact each other.  Real protection should not be expected on an Open SSID.
  • 8.  RE: Disable Client to Client on guest network???
    Posted Mar 17, 2017 09:25 AM
    I agree with u, so how can i do this using policies
    Can you please give me an example (as i told you before, I'm new with Aruba).
