Network Management
Disable Flash in Airwave
  • 1.  Disable Flash in Airwave
    Posted Dec 18, 2015 10:48 AM
    Hey,
    we upgraded from Airwave 7 to 8 and the new HTML5 VisualRF looks geat. But if I go to APs and Devices, choose an AP, Goto monitor and I click on the area for locating the AP, Airwave opens the Flash Version of VisualRF.
    I tried some things like disabling HTML5 and enableing it afterwards, other browser, deleted all APs form the floor plan an added them new to the HTML5 plan .... but still the same.
    Is this a problem, or normal??!
    Greets
  • 2.  RE: Disable Flash in Airwave
    Posted Dec 20, 2015 12:18 PM
    We're running 8.0.9.1 and seeing this issue as well. I've been meaning to open up a ticket as I imagine it should be linking to the HTML5 version of the map.
  • 3.  RE: Disable Flash in Airwave
    MVP EXPERT
    Posted Dec 21, 2015 10:43 AM
    Have you tried turning off support for HTML 5 in VisualRF?
    VisualRF -> SetUp -> Enable HTML5-based UI:  (yes/no)
    You'll need to select another menu (..such us AMP Setup) so that VisualRF can reload.
  • 4.  RE: Disable Flash in Airwave
    Posted Dec 22, 2015 03:26 AM
    Yes, I did this. I have an open support case. Thanks so far.
  • 5.  RE: Disable Flash in Airwave
    Posted Dec 30, 2015 02:20 PM
    This would be a small change in code mapping the right URL for the Floor Plan in AP. Instead of https://airwave/site?... it should map to https://airwave/vrf?... in the URL when you click on Locaton in AP Monitor page.
    This has been fixed in 8.0.10 version.
