Network Management
Disable IDS event in Airwave
  • 1.  Disable IDS event in Airwave
    Posted Feb 16, 2021 03:35 AM
      Is it possible to disable IDS event on Airwave. I mean Under RAPIDS --> "IDS Events" page in Airwave I have about 100k event and it is creating noise on my NMS, is there a way to disable the IDS event in Airwave? Thanks in advance.
  • 2.  RE: Disable IDS event in Airwave
    Posted Feb 16, 2021 12:38 PM
    We can disable IDS event in controller or IAPs itself.
    We have option under AMP Setup > General > Additional AMP Services > Enable Syslog and SNMP Trap Collection: setting, disable this option will stop processing all events.
    We have setting Ignore IDS Events from Remote APs:  under rapids> setup > filter options, enabling will ignore events of RAP.
    Pavan Arshewar
    Principal Network Engineer
    If my post addresses your query, give kudos!
