disable language selection on operators portal
  • 1.  disable language selection on operators portal
    Posted May 17, 2016 09:45 AM
    When  the operators login on guest portal, the only option they have is create a single user guest account.
    But in the main portal the have "change language selection" (Cambiar idioma). You can see attchment.
    How can I disable or hide this option?
    EF
