Disable peer blocking on 205H
  • 1.  Disable peer blocking on 205H
    Posted Jan 11, 2016 01:19 PM
    I just started using my Aruba 205H AP and P2P gaming seems not to work anymore as well as wireless printing. I've checked all settings on the 205 and can't find any settings that enable/disable peer-peer communication. Does the 205H by default block P2P apps/communication? If so, how do I disable it?
    #AP205
  • 2.  RE: Disable peer blocking on 205H
    Posted Jan 11, 2016 01:31 PM
    On the SSID, make sure broadcast filtering is off.  Try that.
  • 3.  RE: Disable peer blocking on 205H
    Posted Jan 11, 2016 09:50 PM
    Thank you. I changed it from ARP to Disabled, but still no success.
  • 4.  RE: Disable peer blocking on 205H
    Posted Jan 11, 2016 11:35 PM
    Do you have firewall policies assigned to users?  Please disable that.
  • 5.  RE: Disable peer blocking on 205H
    Posted Jan 11, 2016 11:46 PM
    No. I haven't created any firewall rules nor did they previously exist.
  • 6.  RE: Disable peer blocking on 205H
    Posted Jan 11, 2016 11:49 PM
    Are the devices on the same subnet?  Can they ping each other?  publish your SSID configuration, because I am just guessing based on what you tell me.
  • 7.  RE: Disable peer blocking on 205H
    Posted Jan 12, 2016 10:02 AM
    Sorry, I forgot to mention that no I cannot ping other clients on the same subnet. The clients are not firewalled. Here are some dumps that I think may help:
     1/12/2016 6:57:33 AM    Target: 00:0b:86:f5:ef:d6    Command: show datapath bridge
    Datapath Bridge Devices
    Flags: F - source-filter, T - trusted, Q - tagged, I - IP
           S - split-tunnel, B - bridge, M - mesh, P - PPPoE
           C - content-filter, O - corp-access, h - to HAP, f - to FAP
           h - dhcp-redirect b - blocked by STP
    Dev  Name                      VLANs  PVID  ACLs         FramesRx  FramesTx  Flags
    4    eth1                      1      3333  132/0     0        0         0  FB
    5    eth2                      1      3333  132/0     0        0         0  FB
    6    eth3                      1      3333  132/0     0        0         0  FB
    7    bond0                     4095   1       0/0   106     1586      2176  FTQB
    13   br0                       0      1     105/0     0     2567         0  IB
    17   aruba000                  1      1     134/0     0     3269      4316  B
    18   aruba100                  1      1     134/0     0      800      1712  B
    Datapath Bridge Table Entries
    Flags: P - Permanent, D - Deny, R - Route, M - Mobile, X - Xsec, A - Auth
    AP Flags: X - Awaiting 1X reply, B - Block all non-1X traffic, F - Force bridge role
          MAC          VLAN  Assigned VLAN  Destination  Flags  AP Flags  Bridge Role ACL
    00:0B:86:F5:EF:D6  3333  3333           local        P                              0
    00:0B:86:F5:EF:D6  1     1              local        P                              0
    C8:E0:EB:17:CB:2F  1     1              dev17                                       0
    C8:F6:50:07:B6:F0  1     1              dev17                                       0
    6C:70:9F:51:52:F8  1     1              dev17                                       0
    40:E2:30:C0:20:87  1     1              dev18                                       0
    D8:EB:97:B3:CA:EE  1     1              dev7                                        0
     1/12/2016 6:56:42 AM    Target: 00:0b:86:f5:ef:d6    Command: show l3-mobility datapath
    L3 Mobility Datapath Home Table
    Client Index  Client MAC  Home Vlan  Destinaton Device Index
    L3 Mobility Datapath Foreign Table
    Client Index  Client MAC  Home Vlan  VAP Vlan  Destinaton Device Index  HAP IP  Virtual Controller IP  Packets Forwarded
    L3 Mobility Datapath Tunnel Table
    Tunnel Device  Remote Protocol  Dest IP  Clients  Idle Time  Rx Packets  Tx Packets  Rx Mcasts  Tx Mcasts  ARP Proxy Pkts  Tx Jumbo  MTU  Rx HB  Tx HB  MTU Reqs  MTU Resps  HB Mismatch  IP Mismatch  Type  Vlan Translations
     1/12/2016 6:54:05 AM    Target: 00:0b:86:f5:ef:d6    Command: show ap bss-table
    Aruba AP BSS Table
    bss                ess               port  ip             phy    type  ch/EIRP/max-EIRP  cur-cl  ap name            in-t(s)  tot-t
    40:e3:d6:00:00:30  ThinkForYourself  ?/?   192.168.0.112  a-VHT  ap    132E/21/21        3       00:0b:86:f5:ef:d6  0        1h:10m:4s
    40:e3:d6:00:00:20  ThinkForYourself  ?/?   192.168.0.112  g      ap    1/22/22           1       00:0b:86:f5:ef:d6  0        1h:10m:4s
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:2
    Num Associations:4
     1/12/2016 6:53:18 AM    Target: 00:0b:86:f5:ef:d6    Command: show access-rule-all
    Access Rule Name :default_wired_port_profile
    In Use           :Yes
    Access Rules
    Dest IP  Dest Mask  Eth Type  Dest Match  Protocol (id:sport:eport)  Application  Action  Log  TOS  802.1P  Blacklist  App Throttle (Up:Down)  Mirror  DisScan  ClassifyMedia
    any      any        IPv4/6    match       any                                     permit
    Vlan Id           :0
    ACL Captive Portal:disable
    ACL ECP Profile   :default
    CALEA             :disable
    DPI error page URL:
    Bandwidth Limit   :downstream disable upstream disable
    Access Rule Name :wired-instant
    In Use           :Yes
    Access Rules
    masterip  0.0.0.0    IPv4/6    match       http                                    permit
    masterip  0.0.0.0    IPv4/6    match       6:4343:4343                             permit
    any       any        IPv4/6    match       dhcp                                    permit
    any       any        IPv4/6    match       dns                                     permit
    Vlan Id           :0
    CALEA             :disable
    DPI error page URL:
    Access Rule Name :ThinkForYourself
    In Use           :Yes
    Access Rules
    Vlan Id           :0
    CALEA             :disable
    DPI error page URL:
  • 8.  RE: Disable peer blocking on 205H
    Posted Jan 12, 2016 12:53 PM
    It is curious that you cannot ping those devices when on the same VLAN.  Something is happening, here....
  • 9.  RE: Disable peer blocking on 205H
    Posted Jan 12, 2016 01:11 PM
    I agree. With my previous AP (Cisco 3700) AP there were no issues. The issue only happens with the 205. When I get the time I will attach the AP to a hub an run Wireshark to follow the packets.
  • 10.  RE: Disable peer blocking on 205H
    Posted Jan 12, 2016 06:07 PM
    My sincere apologies. I made 2 mistakes in my last test:
    1. I had configured the wireless printer for another SSID (old Cisco access point) in order to print and neglected to configure it back for the Broadcast filtering test.
    2. I pinged a client that had dropped off the network but was still in the association table.
    I had just realzed the first mistake today so I ran both tests again it its working. Many thanks to you!!!!!!!
