Cloud Managed Networks
Disable POE per port via central
This thread has been viewed 24 times
  • 1.  Disable POE per port via central
    Posted Apr 06, 2024 05:25 PM
    Where do you disable POE for a switch port in central? Or can it only be done via multi-edit changing the config? If so what is the line I need to add?
  • 2.  RE: Disable POE per port via central
    Posted Apr 07, 2024 08:19 PM
    with multi-edit you need this command
    int x/y/z
      no power-over-ethernet
  • 3.  RE: Disable POE per port via central
    Posted Apr 08, 2024 11:35 AM
    Thanks. I was able to add the config line to one port but it will not add to a second port. I add the line in multi edit, click save and it just never appears. Nothing in audit trail to indicate it is trying or failing.
  • 4.  RE: Disable POE per port via central
    Posted Apr 08, 2024 05:54 PM
    it works for me.
    try it again, there must be something in your setup, what does the config status show?
