hi
Is it possible to disable roaming for particular SSID ?
Hi, why are you looking to disable roaming? I assume L2 roaming?
Only real way I know to effectively prevent roaming is to have unique SSID per AP; this has numerous side-effects though.
What goal are you trying to achieve?
