Disable_speeds
  • 1.  Disable_speeds
    Posted Apr 11, 2013 09:20 PM
    Hi
    anyone know where I can disable the speeds 1, 2 and 5.5 mbps in the 2.4 Ghz frequency in my controller
    regards
    Alex.
  • 2.  RE: Disable_speeds
    Posted Apr 11, 2013 09:31 PM
    You can go under the wlan ssid-profile and select the rates you want enable under that ssid
    (controller) (SSID Profile "TEST-SSID-PROFILE-B") # g-tx-rates ?
    1 1 Mbps
    11 11 Mbps
    12 12 Mbps
    18 18 Mbps
    2 2 Mbps
    24 24 Mbps
    36 36 Mbps
    48 48 Mbps
    5 5 Mbps
    54 54 Mbps
    6 6 Mbps
    9 9 Mbps
    You can do it from the GUI : Configuration > All Profiles > SSID > SSID Profile
  • 3.  RE: Disable_speeds
    Posted Apr 15, 2013 12:58 PM
    Thanks Victor
    I don't know if you can help me I want to reduce the coverage area of many of my ap's I thought that just disabling the speeds of 1, 2 and 5 was enough
    regards
    Alex
  • 4.  RE: Disable_speeds
    Posted Apr 15, 2013 01:06 PM
    You can do this under the rf arm profile , you can lower the power.
    Before you make this make sure you do a survey , making this change can impact the coverage in other areas
  • 5.  RE: Disable_speeds
    Posted Apr 15, 2013 01:21 PM
    You can make this changes here : AP-Group >RF management >802.11 (a or g) radio profile > arm profile
  • 6.  RE: Disable_speeds
    Posted Apr 15, 2013 01:51 PM
    Hi Victor
    What is the part that I have to change Acceptable Coverage Index or Ideal Coverage Index ? Could you recommend values ?
    regards
    Alex
  • 7.  RE: Disable_speeds
    Posted Apr 15, 2013 02:02 PM
    You should probably read this doc it will help determine what changes based on the type deployment you have : amount of APs , building structure , etc...
    http://www.arubanetworks.com/wp-content/uploads/802_11nVRDV8_20110913.pdf
  • 8.  RE: Disable_speeds
    Posted Apr 15, 2013 06:15 PM
    Thanks Victor
