Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Disable SSH HMAC-SHA1 Greyed Out
  • 1.  Disable SSH HMAC-SHA1 Greyed Out
    Posted Jan 21, 2021 10:05 PM
    My organization security scanning detected "The remote SSH server is configured to allow MD5 and 96-bit MAC algorithms" on Aruba 7010 with AOS ver8.4.
    The Aruba 7010 controller are managed by Mobility Master, under SSH setting (folder level),  the HMAC-SHA1 is greyed out, is this algorithm mandatory to be enabled? What if I want to disable it to mitigate the vulnerability?
    Will disable HMAC-SHA1 cause issue on communication between the controller and MM?
    hinze a
  • 2.  RE: Disable SSH HMAC-SHA1 Greyed Out
    MVP GURU
    Posted Jan 26, 2021 07:13 AM
    Do you have try using CLI ?
    ACEP / ACMX #107 / ACDX #1281
