Network Management
Disable SSID broadcasting on AirWave Management Platform 8
  • 1.  Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 02:35 PM
    The header says it all.
    I have setup several WAPs accross out site and have had an alarming amount of confusion on people connecting to this Wi-Fi instead of the guest Wi-Fi
    The users who are supposed to connect to this network will be worked with by IT to get them connected so I am not worried about the authorized users. I am just wanting the SSID disabled so it stop showing up on people's phones for them to try and connect.
    I have looked around both on the forms and in the help on Airwave and I cannot seem to find where the switch it located.
    Please let me know if I can provide any additional information.
    Best regards,
    Logan
  • 2.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 02:52 PM
    Do you have a controller or instant APs?
    Are you using Airwave for configuration or just monitoring?
    Two pivotal questions ^^^
  • 3.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 02:55 PM
    Dear Joseph,
    Thank you for the quick responce.
    We are using controllers and Airwave was used in the initial setup so I imagine we are using it for configuration as well.
    Best regards,
    Logan
  • 4.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 04:32 PM
    Do you configure any of the controller configuration through Airwave?
  • 5.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 04:35 PM
    We did when we set it up
  • 6.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 07, 2016 05:18 PM
    So, if you configured it when you set up, is there something specific that you cannot find right now on the configuration?
    EDIT:  Are you saying you don't know where in the configuration to disable SSID broadcasting or you don't know where the configuration is for the controller in Airwave?
  • 7.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 08, 2016 08:11 AM
    I do not know where the configuration to disable the SSID is.
  • 8.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 08, 2016 08:40 AM
    Okay.  Have you seen the Airwave controller configuration guide here?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/14096/Default.aspx
  • 9.  RE: Disable SSID broadcasting on AirWave Management Platform 8
    Posted Sep 08, 2016 08:43 AM
    No but with the guides I can find the answer to my question.
    Thanks for pointing me in the right direction
